    • 6528
    #136
    I am not sure of anything, I make no guarantees, but I am a betting man, I bet I was seeing double.
      • 32261
      #137
      *hint* read the bit about ninja editing
      Anyway, I drove this thing today - OMG I absolutely hate it when this happens, this car runs awesome. It's a stock bottom end with vortec heads, aluminum intake, thumpr cam, headers, flowmasters.... it can do burnouts for days, and does it at the slightest flicker of the throttle, in any gear, at any speed I was driving - which wasn't terribly fast because it was last registered in 2003 by someone else so getting stopped would require some explaining..... why do I hate this? because it runs too good and I'm now considering keeping it around for a bit.... dagnabit!!!!
        #138
        you say that like its a bad thing....
          #139
          Next up, double knit polyester lounge lizard leisure suits, chest hair implants, and gold chains!
          Most 'vettes have girls in the picture, but check this dog out:
          Did you ever find a set of 8" Rallys ?
            • 32261
            #140
            Beags - that picture is funny to me because on Sunday my wife was trying to get our bloodhound to get into the Corvette and she flat out refused (who said bloodhounds don't have taste?)
            nope on the 8" - the rallys from my Buick are on it now, but the tires are too big in the back, small in the front so I'm still searching. I'm honestly considering C4 wheels (either 1st or second types) - I think they'd actually look pretty good and would certainly keep with the low-buck theme of this car.
              #141
              You live right by Monroe, i'm sure they might have "track" days
              They have 2 asphalt tracks..or something. Looking from the stands, the right side might be the same for both ovals..
              Betcha can " open er up" there...
                • 32261
                #142
                I'm sure, however, once I get it licensed/insured/in my name, I'll be less reluctant about bowing a speed limit, and hooning a time or two.
                  • 32261
                  #143
                  So a bit more work
                  twas a big hole in the dash
                  with the aid of 2 wiring diagrams, I wired it up
                  why 2, you may ask? well, I'm glad you asked... apparently someone, somewhere decided they'd rather have the wiper controls on the signal stalk not on the dashboard.... or, according to a Corvette affecionado, the 74-75 Vettes had wiring fire problems (that could be a problem in a plastic freaking car) and this was all that was available. So the dash is 75, the wiring is 77
                  So the gas gauge, oil pressure, and alt gauge work(ish) (gas gauge is tempermental) - need to run another wire and replace the water temp sender to a two prong sender... but it is progress, it runs, lights come on, light switch works - although there's something screwy - both lights on the driver's side come on on low, both lights on the passenger side come on on high beams... as I said, strange. I need the vacuum switch (emergency override) to see if the lights pop up - if they don't, an electric motor is going to be the fix.
                    • 32261
                    #144
                    well, it's now insured and licensed... driven, even. It does have a ways to go, but now it's driveable so it'll happen faster - especially since the GTO isn't driveable.
                    According to my calculations, I need to lower it at least 3", if not 4"....
                    pictures
                    • Old Dog
                      • Jan 2011
                      • 176
                      #145
                      Looking good SBG, just a little over 3 months and its driving and on the road.
                        • 32261
                        #146
                        Thanks, you have no idea how encouraging those words are.
                          • 32261
                          #147
                          So, more work accomplished... well, half way accomplished
                          for seat belts, I need a roll bar
                          so, before I permanently install the carpet, it's time to build a roll bar
                          cut hole to frame
                          build stands to stay above the brake lines and fuel lines
                          lay out design
                          start bending tube
                          buy new jack
                          dammit
                          anyway, I'll carry on tomorrow
                            #148
                            The coolest part of any build is starting with chalk drawings on the floor.
                              • 32261
                              #149
                              suckiest part is when you have to get more tools cause you broke one.... the problem is the jack didn't have a safety port at the top to prevent overjacking....
                              I swear I should simply write a book giving my experiences with some of these companies - the update today is Eastwood has a 1 year warranty, so it's out of warranty. However, the bad news continues - even if I had been within a year, they wouldn't cover it because I "abused" it..... meaning I need to have a tape measure on the jack to make sure I don't overjack....
                              • R442
                                • Aug 2009
                                • 336
                                #150
                                It's amazing how they can build stuff that is designed to break itself and then call it abuse when it happens. Before you write your book make sure you get your cars finished first, you're doing a great job and I enjoy watching the updates.
