    #631
    Crank grind .010 / .010, balance, polish, rod and main bearings, total $269 - he also honed the balancer so it fits better - it was way too tight.
    Given the difference from the stock bob weight - he recomended I run a 28 ounce imbalance flexplate, instead of customizing the 50 ounce and leaving me screwed if I needed to replace it - (he balanced it with a 28 ounce flexplate) - so - there's another $50.
    harmonic balancer was a 28 also? That's not a bad price for a balance job too.
      #632
      I do not speak real good Ford........... can 22 ounces be ground from the 50 flexplate?
      You save $50 and time chasing parts, and also have a easily replaced part?
        #633
        28 ounce flex plate is an off the shelf part - so I'll go that way instead of modifying my 50 - surely I'll have a use for it sometime.
          #634
          Man I wish I could get machine work for that kind of price around here.
            #635
            Why do I even look at things like this.....
            http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
              • 32272
              #636
              ah, the dangers of project creep
              it is pretty nice, though
                #637
                because gauge sets are 200+ anyway! What kind of gauges are in there?
                Since you have to match these things, I'm guessing the Flexplate *AND* Balancer were both 28's ? It's not uncommon to see a stroker go 28oz imbalance from what I've seen, but an HO crank kind of surprises me.
                  • 6529
                  #638
                  b/c its shiny?
                  • pintoboy77
                    • 7172
                    #639
                    Milner I don't weld my floor pans on the bottom I seam seal along the edge and smooth it out real nice and by the time I undercoat it you can't tell you even put new ones in. Looks awesome don't beat yourself up to bad your doing a fine job.
                      • 32272
                      #640
                      x2 undercoating is your friend. Or is this a 5k show car with chromed axles?
                        #641
                        If it don't go - Chrome it!
                        no chrome here.
                        As I was starting to get the next part of the sub frame connectors put in - starting at the relocated front leaf spring pockets - the welder started acting up - CRAP! out of gas. Bottle is in the car - hope to get it refilled at lunch or after work.
                        28 ounce 164 tooth flywheel is an off the shelf part - $45ish. Need to follow up with the crank machine shop about the balancer.
                          #642
                          That's what I'm doing
                          • mrocketscience
                            • 742
                            #643
                            What are you using for a transmission again? Are you using a C4 trans with the 302? If so I think you want the 157 tooth flexplate.
                              #644
                              Rocket - 164 is correct for AOD.
                              The crank balancer assured me that the way he set it up - 50oz balancer and 28oz flex plate is the best way to run with the lighter pistons - and it required minimum material removal from the crank while still using off the shelf bolt on parts. He's been doing this a long time - so I'll go with it.
                              Got one frame connector completed - had to pie cut and bend the rear section to follow the shape of the rear floor, then add a 1 1/2 square tube to fill the gap.
                              I still need to run 3/4 square tube down the rocker flange, then tie it to the subframes in several places - these cars didn't have factory torque boxes up front so this type of reinforcement (added in '64) should help.
                                #645
                                Progress, right on!
                                I've never heard of mixing them, but then again, the engine doesn't care about labels if it's balanced!
