1979 Mercury Capri
    #166
    The change at the track and find out plan sounded pretty cool, then you'll know for sure what each one feels like.
    Jeff's comment on the Air gap is noted.. but within the question:
    Need pics, is the Holley a small ported single plane? If it is, I'd go with the Stealth. It will probably hand the holley it's ass. With the gears your pulling, I'd personally want the dual plane. That's my wholy unscientific opinion, I'd do it because 38 years of magazine brain washing have apparently worked.
      • 32245
      #167
      yes but then the magazines are selling single plane ads so the current "knowledge" is single planes do better racing. Dual plane do "better" in daily driving. Wonder how much it would cost in advertising to get them to say spark plugs with a diamond stamped in the end are better?
      sarcasm aside, I bet you'll do better with the air gap
        #168
        They've always said the single plane / dual plane and I have a single plane torker sitting here that will get it's butt handed to it by the factory dual plane at 4000 rpm ... lol. The Air Gap, based on every test I've read, is either getting a hell of a lot of advertising cash being thrown at the testing, or is just that much better than any old school anything.
        CC used a Stealth on their 400 hp 302 "stock cam" (ahem... yeah, I want to see the part number, but whatever) with AFR 165's. It apparently had the goods for 6200 with a lot more head than a set of P's, with a "stock" cam. In theory, it's a bit smaller than a E303? Like 266 adv. vs. 282?
        I'll stop the internet bench building but I would put the Stealth on it Saturday night if you are going to run Saturday and Sunday. In my mind, that will save you the next set of gaskets when you want to put it back on. Grin.
        • cantvalve16
          • 1558
          #169
          I can't reply to the question of how single planes are on the top end since I've only ever had street cars and never driven at the track before. However, my Ranchero I just sold had a stock 5.0 long block in it with a stock HO cam, 1.5 in. long tubes, Weiand X-cellerator, Edelbrock 600, and full 2.5 in. exhaust, T5, and stock 8 in. rear with 2.79's. The idle-5000 power was great and low speed throttle response was great. I could lug that car in any gear and smoothly pick up speed.
          Don't know how that might be different with the extra 3-400 your car weighs and the E-cam. Hope that helps.
          Bakersfield, CA.
            • 6528
            #170
            One of the guys on the corral said his car lost power going from a small port singleplane to a stealth. He had ported e7 and a Bcam. Said the heads were too small to take advantage of the larger ports of the stealth...
            I have one the other is at my dad's house I want to put them side by side and compair ports
              #171
              Unless he had somebody like Thumper port those E7's, your 40p's will probably walk their dog... let us know how this works out, I'm really curious now. An E to B cam comparo with both manifolds would be interesting too.
                • 6528
                #172
                I put the holley on yesterday feels a little softer on the bottom but I also took a couple degrees out of the base b/c it advances a lot. Its really hard to tell how something is going to run in the Mile when you have a tenth of a mile to test it. It still has lots of wheel spin.
                  • 6528
                  #173
                  The next thing I want to do is hook up my MSD 6al seems there are 2 ways to hook it up, #1. I think one way uses the white wire and you still need the duraspark box? #2. The other you use the magnetic pickup conection. I think this lets you remove the Duraspark?
                  Will the factory tach still work? In #2 do you run a wire from the old coil neg to the tach output on the MSD box?
                  Look at pages 17 & 18 http://www.msdignition.com/uploadedF...structions.pdf
                    • 11707
                    #174
                    Page 18 style is all I've ever seen. Dist triggers MSD directly.
                      • 6528
                      #175
                      I got one of those connectors to plug into the distributor but its only 4" long, I saw some extension cables but they where 6' long. I think I will cut add in wire. Any idea about the factory tach?
                        • 28673
                        #176
                        You can always call the MSD tech line. Expect to be on hold forever but my experience with tech lines has generally been pretty good once they DO pick up. I have a Crane HI6 in my 'Stang so I have no direct experience with these units.
                          • 6528
                          #177
                          Well I never posted the results from the last Maxton Race. I did not get all the parts put on that I wanted. Frist run left in 3rd to see how high it could turn up got a 131.8 ~5700 rpms the next two runs I used 4th but it was a dog when shifted. 133.8 and 133.1 I am guessing this intake did not help it any. I never really entered the $5k challange but I have less than $3k in it closer to $2500 if you don't count the parts that never made it on the car. Fastest pass ever 137.7 MPH still have not made it to the short track with this car. So what rank would I be?
                          I did not meat my mph goal or set a record with this car. The ECTA has moved to Ohio. My street car is faster than my race car....I think I will play with it for a little while.
                            • 6528
                            #178
                            Have not touched my Capri sence the last Maxton race 3 months ago and have no real desire to, I am tired of it being a race only car but don't want to have to tag tax and insure another car. I can not deside if I want to sell it or part it out, but I am not willing to loose my @$$ on it. I could hang on to it for a while longer its not costing me anything and other than killing grass its not hurting anything where it sits. I have thought about using the drivetrain for somthing else like my old falcon or trying to find a fairmont wagon. If I sit on it long enough maybe I will want to do somthing with it....
                              • 6528
                              #179
                              Been about 6 months since I touched the Capri so I figured I should crank it and drive it around the yard a little. I fill up a bucket with water to refill the radiator. I pulled the lower radiator hose last fall b/c it only had water in it b/c it is a "Race Car" you never know it could blow up and cleaning up antifreeze is a pain. As I was pouring water into the radiator I could hear water running on the ground it was leaking some around the lower hose so I kept pouring, well it was not filling, after closer inspection I noticed it was running out of the block found 3 freeze plugs on the ground. This did not stop me from driving the car took bit of cranking to it fired up (should have put some gas in the carb) Drove it out of the field into the driveway and stole two of the tires for my DD mustang I never knew there was enough water still in the block to push out the freeze plugs, hopefully they did their job and that’s all it needs. I am still not motivated to do anything with this furd. Open headers do sound good though!
                                #180
                                Always a good idea to put valves on the block drains near the oil pan rails if you know you're going to have water in it.... I rarely remember to do that! Good thing the freeze plugs did thier job!
