The ride height in the front finally drove me to the edge. I could not stand it any longer so Saturday afternoon I set out to fix it.
I'm getting really good at r&ring fox body front springs. Do not pass go and go directly to mashing the spring with the hydraulic press and wiring them down. Makes installing them soooooooo much easier.
I lopped 1 coil off the passenger spring and 1.25 off the driver's side. This dropped the front end 1.5" and really improved the looks in my opinion. For some reason, if the front springs are the same length, the ride height will be higher on the driver's front. This ends up preloading the opposite corner (pass rear), which is not really what you want. I do know the car has been hit before so maybe the car is tweaked a bit. The ride heights are all even now left to right so at least it looks normal when parked! I rolled it back and forth and bounced on the front end, but have not driven it yet, so it may settle a little more.
