Ha! We all know you have a small trailer and a hitch.......plenty of room for skis/boots/poles/etc.
Whether you can or can't, you are usually right.
This is the internet, we can be unreasonable
It's a hatchback, perfect for ski's!
" Because your cylinder heads have to babysit an angry mob of pumping cylinders.."
Drag Week 2011 - BB N/A - 1977 Skylark w/455 EFI and TKO-600!
Drag Week 2012 - Street Race BB N/A - DNF on Day 6 - 1977 Skylark w/455 EFI and TKO-600!
Thanks.
These are the stock 71 style block mounts. Note they are asymetric, by swapping side to side you get almost an inch of engine set back. Hilarity ensues when you have to rework headers.
This is my home made frame mount which uses the stock rubber sandwich motor mount. The white lines show the orginal position and shape. The net is I could drop the engne down and inch and move it back almost another full inch. Fortunatly I did all thses things at the same time so I only reworked the headers once. Then built a new set for the A -460 heads.
If I end up going Fox I will likely go with an Afco k-member and fabricate from there unless the subject vehicle already has one.
Oddly enough a big benefit of the BBC exhaust port flange on the A-460 head is that headers are off the shelf, with more choices of tube size etc. for BBC/Fox combinations and cheaper than BBF/Fox headers.
Also had to do this: make lower cross member removable and offset.
Drag Week 2012 - Winner Street Race Big Block Naturally Aspirated - Big hat no horses
Drag Week 2013 - Watching the live feed
Drag Week 2014 - Maybe I'll go faster with a 1000 fewer pounds?
I aspire to hack-perfectionist status.
Last edited by TheSilverBuick; March 2nd, 2012 at 10:16 AM. Reason: *Nested Quotes are way better and meaningful.
would that be amatuer hack? or an amahack? wonder if there's an Olympic event for it
but enough about that...
a Texan who skis? oh good lord
A ninja editor![]()
who's heavily into Buicks
I can just see him out of the slopes with a 10 gallon cowboy hat...
A ninja editor![]()
Loooool. We're not far from the slopes in New Mexico. Been skiing since I was a kid. It snowed on us all day long. Makes for a long day with the kiddos sometimes.
Oh and no ten gallon hats in sight!!
1983 Mustang GT 545/C6 - 10.56 @ 127.38 - www.foureff.com - Four Eyed Fords Forum
Drag Week 2012 - Street Race BB N/A runner-up
