Lincoln Mark VIII
    • 6529
    Re: Lincoln Mark VIII
    I put the dual throttle return springs on yesterday and installed the battery correctly in the box.
    • terry russell
      • 1099
      You looking for 140 out of it also?
      terry
        • 6529
        I have not set a goal for this car, just "want to see what she'll do" I am thinking that speed is going to be limited by the computer before 140. I think it will be between 125-130. I am hoping to pick up the SC Wed. so that will take most of my free time and $$$
          • 6529
          Had a bad skip that started in a rain storm, luckily it only took plugs and wires to fix. Made 3 runs at Maxton, the first time out made a easy shake down of 124.7 mph second time out gave it a WOT the whole way and made my best pass of the day 130.689. The third run I taped / cardboard the grill this time it hit the speed limiter right before the line and lost speed did not have time to pick back up went through the lights at 129.696.
          • terry russell
            • 1099
            That is a very nice car.It ran better than most stock cars.
            terry
              • 6529
              terry
              Thanks Terry!
              correct me if I am wrong but I think if I can fit a 29" tall tire it should be able to run 139+ before the speed limiter kicks in....
              • min301
                • 8552
                130 is sweet, for a stock Mk. 8.
                Good job...
                  NICE WORK!
                  • terry russell
                    • 1099
                    A 28.5 tire is all that you can get under a tbird.Will your car pull that much gear?
                    terry
                      I have some tbird 5 lug wheels factory aluminum - if you want them for spares / tire size options at the track, they're yours.
                        • 6529
                        terry
                        I don't know I like to think it will be.
                        the stock tire size is 225/60/16 I have been using 26.6" for this tire is that a good number or is there a way to measure the tire? My math says that 5100 rpm 3.08 rear 26.6 tire 131 mph. Use a 28.5 tire same 5100 3.08 = 140. Equivalent gear 5100 rpm 140 mph 26.6 tire = 2.88 gear
                        Thanks Milner I may have to take you up on that what size are the rims? I do have a set of 4 15" tbird wheels off my new parts car ;D I love parts cars!
                        • terry russell
                          • 1099
                          turn the limiter off+ go taller tire.
                          then see what it will do.
                          terry
                          • shadetree
                            • 20
                            We ran 134.268 in a bone stock Mk8 back in 2000 at maxton (Our first trip down there) and got stopped by John Beckett (The Race Director back then) cause we didn't have a roll bar. The car had lots more left,just didn't want to cage it. Built the Underdog RX7 with full cage so we could break 200! Have fun with the Mark and go to the Lincolns of Distinction web sight for more info on changing the rev limiter RPM!
                              • 6529
                              Did you have a stock tune when you ran 134? I went to LoD looked around a little all I saw was get a chip or tuner. Do you know of a cheap / free way to remove the speed limiter, I think I want to leave the rpm limiter alone it was shifting at 6200. Also they say you need a new drive shaft b/c the other is not balanced enough?
                              Call me crazy but if I have to spend money on a chip, then why not spend a little more and change it to mega squirt?
                                • 6529
                                #30
                                The ones in bold are the ones I think I could use
                                Tire sizes and theoretical diameter:
                                15 30 35 40 45 50 55 60 65 70 75 80
                                185 19.37 20.10 20.83 21.56 22.28 23.01 23.74 24.47 25.20 25.93 26.65
                                195 19.61 20.37 21.14 21.91 22.68 23.44 24.21 24.98 25.75 26.52 27.28
                                205 19.84 20.65 21.46 22.26 23.07 23.88 24.69 25.49 26.30 27.11 27.91
                                215 20.08 20.93 21.77 22.62 23.46 24.31 25.16 26.00 26.85 27.70 28.54
                                225 20.31 21.20 22.09 22.97 23.86 24.74 25.63 26.52 27.40 28.29 29.17
                                235 20.55 21.48 22.40 23.33 24.25 25.18 26.10 27.03 27.95 28.88 29.80
                                245 20.79 21.75 22.72 23.68 24.65 25.61 26.57 27.54 28.50 29.47 30.43
                                255 21.02 22.03 23.03 24.04 25.04 26.04 27.05 28.05 29.06 30.06 31.06
                                265 21.26 22.30 23.35 24.39 25.43 26.48 27.52 28.56 29.61 30.65 31.69
                                275 21.50 22.58 23.66 24.74 25.83 26.91 27.99 29.07 30.16 31.24 32.32
                                285 21.73 22.85 23.98 25.10 26.22 27.34 28.46 29.59 30.71 31.83 32.95
                                295 21.97 23.13 24.29 25.45 26.61 27.78 28.94 30.10 31.26 32.42 33.58
                                305 22.20 23.41 24.61 25.81 27.01 28.21 29.41 30.61 31.81 33.01 34.21
                                315 22.44 23.68 24.92 26.16 27.40 28.64 29.88 31.12 32.36 33.60 34.84
                                325 22.68 23.96 25.24 26.52 27.80 29.07 30.35 31.63 32.91 34.19 35.47
                                335 22.91 24.23 25.55 26.87 28.19 29.51 30.83 32.15 33.46 34.78 36.10
                                345 23.15 24.51 25.87 27.22 28.58 29.94 31.30 32.66 34.02 35.37 36.73
                                355 23.39 24.78 26.18 27.58 28.98 30.37 31.77 33.17 34.57 35.96 37.36
                                365 23.62 25.06 26.50 27.93 29.37 30.81 32.24 33.68 35.12 36.56 37.99
                                375 23.86 25.33 26.81 28.29 29.76 31.24 32.72 34.19 35.67 37.15 38.62
                                16 30 35 40 45 50 55 60 65 70 75 80
                                185 20.37 21.10 21.83 22.56 23.28 24.01 24.74 25.47 26.20 26.93 27.65
                                195 20.61 21.37 22.14 22.91 23.68 24.44 25.21 25.98 26.75 27.52 28.28
                                205 20.84 21.65 22.46 23.26 24.07 24.88 25.69 26.49 27.30 28.11 28.91
                                215 21.08 21.93 22.77 23.62 24.46 25.31 26.16 27.00 27.85 28.70 29.54
                                225 21.31 22.20 23.09 23.97 24.86 25.74 26.63 27.52 28.40 29.29 30.17
                                235 21.55 22.48 23.40 24.33 25.25 26.18 27.10 28.03 28.95 29.88 30.80
                                245 21.79 22.75 23.72 24.68 25.65 26.61 27.57 28.54 29.50 30.47 31.43
                                255 22.02 23.03 24.03 25.04 26.04 27.04 28.05 29.05 30.06 31.06 32.06
                                265 22.26 23.30 24.35 25.39 26.43 27.48 28.52 29.56 30.61 31.65 32.69
                                275 22.50 23.58 24.66 25.74 26.83 27.91 28.99 30.07 31.16 32.24 33.32
                                285 22.73 23.85 24.98 26.10 27.22 28.34 29.46 30.59 31.71 32.83 33.95
                                295 22.97 24.13 25.29 26.45 27.61 28.78 29.94 31.10 32.26 33.42 34.58
                                305 23.20 24.41 25.61 26.81 28.01 29.21 30.41 31.61 32.81 34.01 35.21
                                315 23.44 24.68 25.92 27.16 28.40 29.64 30.88 32.12 33.36 34.60 35.84
                                325 23.68 24.96 26.24 27.52 28.80 30.07 31.35 32.63 33.91 35.19 36.47
                                335 23.91 25.23 26.55 27.87 29.19 30.51 31.83 33.15 34.46 35.78 37.10
                                345 24.15 25.51 26.87 28.22 29.58 30.94 32.30 33.66 35.02 36.37 37.73
                                355 24.39 25.78 27.18 28.58 29.98 31.37 32.77 34.17 35.57 36.96 38.36
                                365 24.62 26.06 27.50 28.93 30.37 31.81 33.24 34.68 36.12 37.56 38.99
                                375 24.86 26.33 27.81 29.29 30.76 32.24 33.72 35.19 36.67 38.15 39.62
