double blower
  • 67prostreet
    • Jun 2008
    • 1971
    double blower
    On you-tube there is 70 GTO with a double blower setup. Is that thing a real hot rod or just for show. I know it runs but haven't seen it do anything other than idle around.
  • Clif
    • 19
    Re: double blower
    I've seen old photos of dragsters from the 60's with two GMC blowers stacked on top of each other. I was also wondering the benefit of this. I guess it's probably like dual stage supercharging where the first blower compresses the air/fuel mixture, then the second blower compresses the already compressed mixture even more for even more boost??? Does this sound right or am I off base?
    Clif
      Re: double blower
      could work that way....seems like the air would get kinda warm though
      • fahrenschnell
        • 6787
        Re: double blower
        I could only see this working in an alcohol motor.....2 blowers would create a ton of heat....especially with 2-Stage compression....
        Go feel the air compressor tank after it has been running a while....
        Alcohol could reduce the heat drastically...
        Seth
        200 mph or bust.......
          Re: double blower
          I think I saw a spot in CC or HR back when they used to do cruise-in "hometown" spots on a dragster that did the stacked blowers saying it made the same boost, just got there faster. Honestly being positive displacement devices that wouldn't make much sense unless you ran them slower. Every roots style system has a spot where the rotors move fast enough to keep them sealed against the case but not so they are really squeezing the air so hard the adiabatic effiecency drops dramatically. I could see spinning them slower and getting the same boost with more effeciency on the setup if you kept them both in the range but it sounds more trouble than it would be worth getting it setup right.
            Re: double blower
            Wouldn't you rather have a Buick 8)
            • malc
              • 5333
              Re: double blower
              • BigBlockMopar
                • 3498
                Re: double blower
                I recon the view will be 'great' from behind the wheel... lol
                "No officer, I really didn't see that 18-wheeler in front of me. I don't know where it came from when I hit it..." :D
                www.BigBlockMopar.com
                  Re: double blower
                  Different setups, this is I beileve that same GTO with the blowers stacked on top of one another not side by side which is like early multi carb setups, just an attempt at getting more blower on the motor.
                  • joebogey
                    • 1312
                    Re: double blower
                    Not sure where, but I think I remember reading that the GTO only had the lobes in one of the blowers. The other had the front and rear gear setups with the pulley and belt, but was and empty case.
                      Re: double blower
                      Dobertons old Chevy II had a blower with twin Turbos on it
                        • 11725
                        Re: double blower
                        one goofy lookin' GT(f)O if you ask me.
                          Re: double blower
                          yeah, that's silly.
                          • tiresmoke!
                            • 4466
                            Re: double blower
                            Pro Fairgrounds, anyone?
                            • 84ta406
                              • Sep 2008
                              • 10
                              Re: double blower
                              From what I know of the car is it has made some low 10 sec. passes at the track. They did a article on it for PHP magazine a while ago. It does look weird but people are doing similar things with the 03-04 cobras. Theyre using a turbo to feed the stock eaton S/C and making crazy power with it.
