Dumbest thing I've done lately
  • std
    • 3520
    I seem to remember a thread about dumb things we've done. I thought I would share the latest dumb thing I did. Make that the series of painful dumb things I've done.
    I was in Texas the last couple weeks for some Legend racing. When we're not racing, we work on the bosses toys. I was making to make a step for the back of his H1 Hummer so it is easier to get into the bed. I find some 1/4" steel and cut it with the plasma cutter. Now I need to sand the edges. I put a new belt on the belt sander and was adjusting it and I don't know what I did but I stuck my fingers right into the belt. A little blood, but mostly sanded down finger nails and a bunch of pain. And I ruined my last belt!
    I bend the metal 90 degrees and go to the drill press to do the mounting holes. Jimmy comes up and says "Are you going to helicopter some parts?". You'll never guess what happens next. As soon as I touched the part with the drill bit, it caught and spun around and smacked me on the side of the wrist. No blood, but way more pain and a bruise about 3" x 3" a couple days after the swelling went down.
    Don't stop reading, the best is yet to come!
    We just moved onto a new shop a couple weeks ago. I get back from Texas and start helping put stuff away and sort out some of the electrical we need. Whenever the compressor kicks on It's way to loud, so we start to build 7' x 12' a room around it. We lay out the walls on the floor and I nail them together. The other guys were doing something so I grab the short to move it out of the way. I get it about chest high and it slips out of my hands and lands right on top of my right foot. That was some bad pain. the kind that gives you an upset stomach. I had to sit down immediately.
    I drove myself to the hospital(cause I'm a guy, not a sissy) and guess what. I broke my foot. First metatarsal. Lots of bruising and swelling. That was last Wednesday. I go to a specialist tomorrow.
    All that in a week. I think I'm done with pain for the year.
    Cognizant Dissident
    Re: Dumbest thing I've done lately
    I'm thinking you need to wear a helmet whenever you get near a tool. :D
    Three words: Steel Toed Boots.
    • Bamfster
      Lord God King BangShifter
      • 10445
      Time for a vacation.....
      • A/Fuel
        • 4520
        Originally posted by TC
        • Screaming Detroit
          • Jun 2008
          • 912
          I was working on my motorcycle adjusting the carbs, 74 XS650 the electric starter doesn't work,so I was using the kick startand were it bolts on the motor it cracked and spun sideways. So instead of fixing it right I did the quick fix and buzzed a quick bead of weld over the crack put it on, kicked the motor over about 3 kicks the lever broke of went in my leg made my calf into hamberger spent 3 hours in the ER on crutches out of work for a couple of days
          Original Carjunkie TV Member
          • std
            • 3520
            I've never missed a day of work because of an injury. I get all the usual bumps and cuts and bruises you would expect from working with my hands, but I've never had a streak like that. And the only one that slowed me down was the broken foot.
            I don't especially like the forced vacation.
            Cognizant Dissident
            • Brad54
              • 810
              I've gone to the ER once in my adult life, because I couldn't get the fish hook out. Other than that, my rule is pretty much if a stitch or three will close it, don't bother. I broke my toe in the shop, but didn't need them to tell me, and they weren't going to put a cast on it. I'm usually pretty careful though, so I avoid a lot of injuries.
              However, last week, I was reheating some food in the oven, and since we were all out of glass dishes, I put it in a metal pan with lid. Pulled it out of the oven just fine. Got the steak on the plate, set it down grabbed the rolls out of the toaster oven, then noticed all the good, buttery drippin's in the bottom of the pan. "Well I can't let THAT go to waste! I gotta put it on the steak." Grabbed the handle, swung it over the steak, and realized something was very wrong.
              2nd degree burns across the palm of my hand, all five fingers (with blisters on the tips), down the side of my index and little finger, and honest-to-God left a finger print on the underside of the handle.
              After trying to tough it out for an hour, I finally went to the ER. They put some creme on it that was amazing, wrapped it up like the Hamburger Helper mascot, gave me a shot in the ass for pain and a prescription for oxycodone.
              That was the dumbest thing I've done in A LONG time!
              As for helicoptering parts, if you aren't going to clamp it down (and I often don't), then you MUST set the work piece up on the table so that the far end comes to rest up against the drill press's pipe. It's our instinct to set the piece up to our right, but when the drill grabs it, it now slams into us. If we set it up so the piece spins away from us and hits the pipe, then you have a much better shot at avoiding injury.
              -Brad
              • HotRodLadyCrusr
                • 381
                Brad's so tough he didn't even go to the hospital when he got hit by a car a couple of years ago :o ;D
                • Schtauffer
                  • 5320
                  I took a call from a guy today who wanted to get his garage door open after his wife hit it with the car and jambed it part way open. I warned him to be careful, because if the springs let go they will break your arm or head or whatever is closest. He said (I kid you not), "Ok, I'll use a sawzall and wear a bicycle helmet."
                  The official Bangshift garage door guru. Just about anything can be built using garage door parts, trust me.
                  • Brad54
                    • 810
                    The guy was only going 35mph when he hit me. I didn't see any bones poking through, and I could still (mostly) walk, so what was the point? Ace bandage on the ankle, a couple advil, a good night's sleep, and I was good to go. Memphis to Atlanta the next day (luckily it was my gas pedal ankle and not my clutch foot), and an enthusiastic "Hi honey, I'm HOME!" when I got there.
                    Twice. ;)
                    My ass and elbow hurt for a week or ten days, I limped bad all the time for about that same period, and every morning for six months. I'd take the car over the burn any time.
                    -Brad
                      Wrap youreself in bubble wrap and stay in bed....
                      • Gary 351C
                        • 3508
                        That sucks! I broke my foot a year ago, I was off work for 3 1/2 months. ....I got lots of work done on the car though ;D.
                        Just groovin' to my own tune.
                        • sedandelivery55
                          • 905
                          OUCH! Sounds like you need to take a vacation to heal up. ;D I broke the first metatarsal on my right foot last year, also. Dropped a 4-jaw chuck off a 25" lathe on it, and the steel toe boots didn't help any at all, missed the toe and landed on the center of my foot. When I showed up for work the next morning, the boss just stared at me and shook his head. I have a high tolerance for pain. I should know, having 'sanded' the ends of my fingers off a few times, tore one off completely, shot myself with nailguns a few times, been run over by a car, and hit by lightning. I guess I lead a charmed life. ;D
                          • A/Fuel
                            • 4520
                            i must admit, i stuck a screwdriver clean through my hand not to long ago...
                            and i had a ambulance ride from joliet a few weeks ago..almost lost my leg from the knee down.
                            i'm not going into any of here but, lets just say......i've had my share.
                            so i have the (or so i think) right to make fun.
                            it's all good.....be safe out there.
                              Here's one that will make all of you feel better. Thankfully, it didn't happen to me. When I was in high school my buddy and I were in the weight training room getting ready to do bench presses. Bill was talking a mile a minute. He was so excited because his girlfriend let him get to second base that past weekend. He was describing the whole bloody date to me as he was putting the weights on the bar bell. Bill was so involved in his story, he wasn't even watching what he was doing. He was trying to put a 45 pound plate on the bar and thought it was on when he let go of it. Well, it wasn't on the bar and the plate dropped straight down on his foot. I heard the crack it made when it hit his foot and the sound that he made one second later. Two sounds I don't want to hear again in my lifetime.
                              I walked with him as the paramedics rolled out to the ambulance along with the gym teacher. The gym teacher kept asking me if I was alright and I kept saying yes. Then he asked why I was limping. I guess it was what I saw. I limped for the rest of the day.
