Duramax transmission options
  • Matt Cramer
    • 2268
    So, I've got a '72 C10 with a damaged block, and can't really seem to justify expensive block repairs on a stock 350. So I've been daydreaming about engine swaps, and happen to know where there's a Duramax diesel available from sometime around 2007-2008. Just the engine, sitting on a pallet. No transmission or anything.
    There's a lot of things I'd have to research to do such a swap, but one total unknown is what to use for a transmission. The truck is currently an automatic and it may be most practical to keep it that way. What sort of automatic would hold up behind this and not be too expensive or bulky?
  • tardis454
    • 3614
    Built 4L80E/6L80E, Allison, or NV5600..
      not too expensive? probably the SM465 granny low 4 speed
      • rightpedal
        • Jun 2008
        • 1258
        Is the bolt pattern on the duramax the same as standard chevys?
        Steve
        Well I have stopped buying stuff for cars I don't own. Is that a step in the right or wrong direction?
        • tardis454
          • 3614
          Steve
          Yep, bolt boss at the peak is used also...
            does the engine have the wiring harness and computer? If not - price that stuff out from a junkyard first.
            older mechanical diesels are a lot easier to swap, but also a lot louder and less efficient, but way way way less complex.
            Not sure what an allison costs used - but i'm guessing a few grand. may be more cost effective to start out with a totalled truck and sell off the engine and other parts you don't use - keep the wiring, computer, transmission, transmission computer, etc.
              4L80e and megashift =P
                4L80e is overrated turkey
                tons better than the competition but the 6L90 smokes it
                get the allison and hack up the floor
                I don't understand the diesel love though ..after you have done 10 or 50 sets of injectors back in 2004 , you get over it
                • tardis454
                  • 3614
                  Why bother with diesel when you can buy a drop out 5.3 motor for under a grand...
                  http://www.ebay.com/itm/02-Chevy-Sil...-/290910662537
                  • Matt Cramer
                    • 2268
                    That is the obvious choice, and what I have been planning to do - but I wanted to weigh my options first.
                      • 28677
                      Buy a 240D and pull the trans and just bolt it in behind your Diesel.
                      Oh wait - that's me........
