Removing Valve Keepers.....
    So my friend calls me yesterday and asks me if I have a valve spring compressor, he's working on a VW head where the valves are bent, I told him I have an air powered spring compressor but that he can just take a socket on an extension and place it on the retainer and smack it with a hammer and it will compress the spring enough to allow the keepers to pop out.... I've done this many times on other heads so I know it works.... So anyone else use this method to remove valve keepers??
    • 28677
    Absolutely! Works great. The hard part is rounding up all the keepers. I just use a deep impact socket w/o extension.
      On VW a engine with such little spring pressures, I'm sure it will work. Might want to soak it all with PB Blaster to loosen the muck that will glue it together.
      I have a $10 valve spring compressor that is just a lever. I've used it on double solid roller springs. Gives a good work out, but works.
      • minipower
        FNG
        • Feb 2013
        • 6
        I do the same as you and DanStrokesit to remove them and go the same route as Scott Ligkitt to put them back-on... But my lever is a Pickle Fork
          I just drop mine in the washing machine with my socks.
            I've found the lever to actually be easier in many cases than the big "c-clamp" style. a light tap with with a rubber mallet and a magnet to fish them out are handy to have nearby.
              They sell a tool that will install them the same way.
              • Caveman Tony
                • Aug 2010
                • 1544
                I wanna see the YouTube vid on how to use a hammer and socket to INSTALL spring keepers, lol...
                  Here you go......
                  • minipower
                    FNG
                    • Feb 2013
                    • 6
                    Holly Crap....I never thought of using a socket to INSTALL the keepers.. Did he say that it was a special tool that holds the keepers apart as you push the retainer down over the valve
                      • 28677
                      Either those are whimpy springs or that guy is a HE-MAN!
                        I used to remove the Keepers on V8 Benz heads with a socket and hammer, though I used a pneumatic spring compressor to put them back on..... Saying that most imports like VW and Toyota have weepy springs that you can compress like that..... Crazy thing is I had to crank up the pressure on my compressor regulator to 125psi to compress the springs on my 406 and it just barely did it...... I don't even think the hammer and socket would work on those......
