switching to 1.6's from 1.5' s lift is easy to figure but how does it change the duration?? is there a way to figure this?
revisited ??? how to figure how rocker ratio effects duration?????
After scratching my head for a minute, it hit me. Duration will not be affected by the rocker ratio change. Duration is based on a point on the camshaft lobe where the lifter starts it's upward movement and finishes its downward movement. Rocker arm ratio has no bearing on this point, thus it does not change and the lifter and pushrod will perform as they had with the 1.5:1 ratio rockers.
RonIt's really no different than trying to glue them back on after she has her way.Comment
The rocker ratio will change the "effective" duration at 0.050" lift (the common measurement for cam duration). This is because the valve action will be different at that measurement point with the change in rocker ratio. The 1.6 rocker will get the valve off the seat and to 0.050" lift quicker (the reverse when the valve closes)...thus, increasing effective duration. Therefore, you've extended the period the valve is open...although slight.
Rule of thumb...switching from a 1.5 to 1.6 ratio will increase your effective duration by about 3 degrees.Last edited by jcharliem; August 17, 2012, 04:06 PM.Nitrous, baby!!...Comment
if not noticable, it was low compression engine.Originally posted by Beagle View Post3* of duration @ .050 is quite a bit when you think about it. Very small numbers make very big differences in this game.
3 degrees is big.
if to wonder about the ratios, they are in everything .. time is distance. I interpret all kinds of things that way.Previously boxer3main
the death rate and fairy tales cannot kill the nature left behind.Comment
it might help a bit, got some old beater 462 heads with2.02/1.60's thought about putting them on with some 1.6 rockers to get a few more rpm's out of my poopy old 355, it now has old 76cc 1.74 intake valve truck heads. running a few hundred rpm's short of making it threw the 1/4 mile in my powerband now.Originally posted by Beagle View Post3* of duration @ .050 is quite a bit when you think about it. Very small numbers make very big differences in this game.
Last edited by oldsman71; August 18, 2012, 08:55 PM.COBEY..... franklin, kansasComment
