I6 Landcruiser intake mods
    Why not just change the pinout of the TPS sensor so it responds with correct open/close voltage without having to reverse the TB direction?
    Otherwise that setup looks pretty awesome to me.
    • BKBridges
      • 918
      DG,
      The "users" are running the stock ECU and the Toyota TPS is a 4 wire with a idle "on" switch... couldnt find a toyota 4 wire TPS that rotated in the other direction (mechanical issue)..I think I found a Mitsu unit that would work, but I ran out of time. I also needed the 6 wire single pole Toyota IAC unit but at 400.00 a pop I demured and gave them a 4 wire unit and my best wishes. They squeezed me both on time frame and cost...Im supposed to make more of these for these guys so hopefully I can upgrade the prototype as we go along.
      BKB
      www.FBthrottlebodies.com
      Bruce K Bridges
        Originally posted by BKBridges View Post
        DG,
        BKB
        What I was suggesting was, let the TPS rotate in the wrong direction, you can re-wire it so that it still reads increasing voltage with increasing RPM. But if it was a physical problem, then I understand.
        Still, what you consider "quickie work" most of us (me included) consider "masterpiece"
        • BKBridges
          • 918
          DG,
          Why thank you!
          BKB
          Bruce K Bridges
          • BOSSMAN
            • Aug 2011
            • 756
            Pretty unique setup? How long are those runners?
            Nick Smithberg
            www.smithbergracing.com
            • BKBridges
              • 918
              Bossman,
              They are about 7in long, combined with the factory manifold base of about 9in. The main criteria from the customer was that it had to stick out of the hood...
              BKB
              Bruce K Bridges
              • BOSSMAN
                • Aug 2011
                • 756
                Be interesting to see what the actual tuned length is for the build. Should make alot more torque!
                Nick Smithberg
