Dudes,
Buford is official among the living again. Cruised the car with the basement TH350 in it this afternoon. All is good as far as shifting through the gears 1-2-3. One thing that it is doing though is that when cruising at light throttle, the trans will upshift from third to second and not back down into third unless I click it into neutral and shift it back into 3rd.
The dipstick does read a little low, so I need to glug some more fluid into it, was just wondering if this is a symptom of a fluid level issue or maybe something else (vacuum modulator adjustment?). I DO NOT have the kick down cable hooked up to the carb linkage at this point, FYI.
Brian
Brian
