91CCFirebird's 1991 Firebird Formula "painted"
  • HoosierGTA
    • 2865
    #91
    Re: 91CCFirebird's 1991 Firebird Formula - mini pre-tour project
    Originally posted by 91CCFirebird
    Dan,
    Would you be interested in parting with that set of wheels? I would like to have a second set of rears to put drag radials on.
    Probably, they have some nicks and such. Still interested , I could go take so pics .Something like $60 would git them away from me.
    • 91CCFirebird
      • 1717
      #92
      Dan,
      send some pics at your leisure, I'm interested, do you have center caps and lug cover as well
      Hard Work Guarantees Nothing - Lack of it Does!
      Drew Gerth - Newburgh, IN
      • mlcraven
        • Sep 2008
        • 1878
        #93
        Decided to strip the clearcoat off the wheels and polish and paint them before the tour.
        Good effort on the wheels! That's worth over $100 a rim if done by a pro in this neck of the woods.
        Michael from Hampton Roads
        • 91CCFirebird
          • 1717
          #94
          Originally posted by 383S-10
          Thats a nice job on the wheels,,,,,,,,,,,,what did you use on the wheels to paint them?
          Thanks, Duplicolor wheel paint.
          • 91CCFirebird
            • 1717
            #95
            Thanks
            The first one had a pretty good learning curve but the second went much faster.
            Number 3 and 4 were stripped tonight.
            I think they will need one more coat of stripper tomorrow then it is back to sanding the top sides.
            • 91CCFirebird
              • 1717
              #96
              Just finished the last one today. Here is a pic complete with freshly painted center cap and lug nut covers.
              • Mr4Speed
                • 2149
                #97
                Ok we saw the dragstrip pics in the Power Tour thread-How did it run?
                Inquiring minds need to know! ;D
                • 91CCFirebird
                  • 1717
                  #98
                  Broke the nitrous switch at about 3/4 track and spun like hell to a poor 15.47
                  • HoosierGTA
                    • 2865
                    #99
                    Well, at least it was spinning ! P.S see pm
                    • 91CCFirebird
                      • 1717
                      #100
                      I have been experimenting a little with some paint. Painted the decklid, wing and, window trim.
                      Before
                      After
                      Final assembly coming as soon as I get some new fender washers.
                      Need to mess with the alignment a little too while it is apart.
                      • tiresmoke!
                        • 4466
                        #101
                        Re: 91CCFirebird's 1991 Firebird Formula - Mini paint project
                        Looks like your hatch is mis-aligned too, Drew.....seems like every 3rd-gen I've ever seen(mine included) has that issue.
                        The paint "experiment" looks good.......gonna get brave and try the roof next?
                        • Mr4Speed
                          • 2149
                          #102
                          They all do that. When the hatch is closed the struts are pushing everything straight back and over time it creeps back. To fix it properly you have to unbolt the metal from the glass, clean all the sealer off, and re-align it with new sealer applied. The glass and metal are both bolted and glued together.
                          • 91CCFirebird
                            • 1717
                            #103
                            I may attempt the roof and hood this winter while it is not roadworthy but I haven't driven it in about two weeks so I am just going to drive it for now. I may work with the alignment this winter but scrape and reseal doesn't sound like any fun to me right now.
                            • HoosierGTA
                              • 2865
                              #104
                              Have looked at my cracking caked on undercoating in my wheelwells thinking ....I should get a heat gun and get the crud out and spray a thin coat back in . Think I'll put mine of too !
                              Repaired spelling so it would make a little more sense.Fixed second and fifth words.
                              • 91CCFirebird
                                • 1717
                                #105
                                Re: 91CCFirebird's 1991 Firebird Formula - Exorcism complete
                                I think I may have finally got the dreaded howling monkies out of the rearend. Just got the car back from having the rearend rebuilt again. This time we used GM gears and synthetic lube. The moise has gone from a 10 to about a 3. I just hope it stays quiet as I get some miles on it. Also installed some new rear brakes, looking forward to putting some miles on it before it is time to put it away for the winter.
