91CCFirebird's 1991 Firebird Formula "painted"
  • 91CCFirebird
    • 1717
    #61
    Re: 91CCFirebird's 1991 Firebird Formula
    Got 300+ miles on the rearend and filled the bottle.......put it through the paces a little this weekend....next weekend I am going to the local 1/8 mile track for a show and some pro tree fun runs as my buddy challenged me to run against his stang. Traction is the main nemisis that may keep me from victory.
    Hard Work Guarantees Nothing - Lack of it Does!
    Drew Gerth - Newburgh, IN
    • HoosierGTA
      • 2865
      #62
      so,has it stopped making racket around turns when up to operating temp?
      • 91CCFirebird
        • 1717
        #63
        changed the limited slip additive and all is well
        • 91CCFirebird
          • 1717
          #64
          The track was a blast and although traction was a problem I hooked better than the mustang. My first run was a 10.22 and I spun all the way down, the stang ran a 10.38. My second run I put some more heat in the tires and went 8.8 but still spun on the launch but hooked after I let off and got back in it. I could only run twice as I had to go to a conference in Indy that evening but it was a total blast and I cannot wait until spring to go run again when the track opens for the season. Definitely need some drag radials.
          • HoosierGTA
            • 2865
            #65
            At first I was thinking the you made it 2 seconds faster just by bringing it to a higher elavation than L.A . Then I saw the 8.8 then I knew you must be running the 1/8 .
            • 91CCFirebird
              • 1717
              #66
              yes it was the 1/8
              • 91CCFirebird
                • 1717
                #67
                Well Santa came a little early here and brought the first load of suspension upgrades.
                Adjustable lower control arms and panhard bar in black
                Lower control arm relocation brackets
                • tiresmoke!
                  • 4466
                  #68
                  Re: 91CCFirebird's 1991 Firebird Formula - suspension parts acquisition phase
                  Hey Drew....
                  Nice parts!
                  Have a link for those? I need to start paying attention to the suspension on mine....
                  • 91CCFirebird
                    • 1717
                    #69
                    Chris
                    It came from UMI performance, Highly recommended on thirdgen.org, and they had 20% off on thanksgiving
                      #70
                      I bought their pan hard bar for my Impala. Best order soon because they get behind on orders in winter.
                      • HoosierGTA
                        • 2865
                        #71
                        Hey glad to see you making progress. It took me 6 wks just to get mine in the garage . I'm sure you'll love what it will do for your car. I put a tubular panard bar in mine a yr ago and it was night an day difference to the stamped steel one .
                        • 91CCFirebird
                          • 1717
                          #72
                          Just received poly a-arm bushings, rear sway bar bushings, and front and rear end links with poly bushings. Hopefully the purse strings will gain a little more room after Uncle Sam sends a check and I can really get to acquiring parts so it will be ready for the Power Tour.
                          • HoosierGTA
                            • 2865
                            #73
                            Great seeing you making some progress. Mine hasn't gotten touched . ( Been busy keeping the Families 4 daily drivers going ! )
                            • 91CCFirebird
                              • 1717
                              #74
                              Just ordered my subframe connectors from Alston Racing
                              • 91CCFirebird
                                • 1717
                                #75
                                36mm front sway bar bushing on the way from spohn.......only place I could find the 36
