91CCFirebird's 1991 Firebird Formula "painted"
  • 91CCFirebird
    • 1717
    #181
    New "to me" motor
    My new motors old home
    The reason my motor was replaced with something a little more radical
    Hard Work Guarantees Nothing - Lack of it Does!
    Drew Gerth - Newburgh, IN
    • Dan Barlow
      ZF6 Bangshifter
      • 10603
      #182
      Congrats. Going to go carburated or keep it injected.
      Previously HoosierL98GTA
      • 91CCFirebird
        • 1717
        #183
        Planning on keeping the TPI. The intake went to someone else.
        • 91CCFirebird
          • 1717
          #184
          a little porting and siamesing on the intake runners
          • Dan Barlow
            ZF6 Bangshifter
            • 10603
            #185
            Are you going to carry the siamising all the way thru?
            • 91CCFirebird
              • 1717
              #186
              I went as far as my bit was long. From my research you are not supposed to Siamese the intake end however they are now port matched to the intake. In the picture the one on the left is done and the one on the right has black sharpie on what is coming out.
              • Dan Barlow
                ZF6 Bangshifter
                • 10603
                #187
                Any plans to extrude hone them. If your not familiar with that it is like a silver abrasive paste they pump thru what ever to open and smooth passages out.
                • 91CCFirebird
                  • 1717
                  #188
                  No plans. The intake needs to go back together. Hoping to make noise at the end of the week.
                  • Dan Barlow
                    ZF6 Bangshifter
                    • 10603
                    #189
                    That'd be super.
                    • 91CCFirebird
                      • 1717
                      #190
                      progress has been slow but I have a teaser pic
                      • 91CCFirebird
                        • 1717
                        #191
                        spark plugs are too long and hit the header, have some shorter ones on order
                        brake preview
                        old fronts 8 inch
                        new fronts 13 inch
                        • Dan Barlow
                          ZF6 Bangshifter
                          • 10603
                          #192
                          From a vette or a b body ? ( Caprice )
                          • 91CCFirebird
                            • 1717
                            #193
                            Vette
                              #194
                              AC Delco's are the same length as Accel's shorty plugs. Better quality and cheaper.
                                #195
                                I ask for AC/Delco... They always put Autolites on the counter.. Then being the smartass I can be I drag out AYE-CEE
                                Only time I go ahead is if I don't have time to make another stop..
                                Kid runs Split Fires on his derby motor.. They last maybe 2-3 derbys. When they get changed, no other changes, even I feel the difference in idle.. sometimes the end cylinders are in the way of the boots..
                                I've run Accels.. Seem ok.. But are a wallet flattener!
