+ Reply to Thread
Page 8 of 9 FirstFirst ... 4 5 6 7 8 9 LastLast
Results 71 to 80 of 90
  1. #71
    Tire Chirper CruizinKev's Avatar
    Join Date
    Apr 2012
    Location
    overseas
    Posts
    50
    thanks ;)
    today's update. test fitted my 20x10 wheel and oh well it looks SWEET!!!! :D
    brought body back on frame, put the stock rear end back on and tested the wheels again - wheel rubs bad on inside of the frame. will try a wheel adapter to make it fit but maybe will also notch the frame a little. but will test with a adapter first.
  2. #72
    Legendary BangShifter SuperBuickGuy's Avatar
    Join Date
    Jan 2008
    Location
    Woodinville, WA
    Posts
    11,979
    Did you put your body bushings in place during the test fit?
    life is too serious to take seriously
  3. #73
  4. #74
    Lord God King BangShifter Scott Liggett's Avatar
    Join Date
    Oct 2007
    Location
    West Los Angeles
    Posts
    17,077
    Fitting 10" wide wheels almost always requires "adjustments" to be made to get them to work. I had some to do on the bulging fenders on my 70 Caprice. I still have a bit of rubbing when entering driveways at an angle.
    Resident Subversive
  5. #75
    Join Date
    Apr 2012
    Location
    overseas
    Posts
    50
    unfortunately front wheels won't clear C5 calipers/brakes without spacers. but I'll get some 20mm adapters/spacers on rear and will try them on front as well.
    fronts are 20x8.5 with 5.25 BS and rears are 20x10 with 5.5 BS
    oh and here some pics of my sweet nice doors :D
  6. #76
    Don't you just love suprises ! thats hot rodding and the reason why our projects end up costing us twice as much as we planned .
  7. #77
    Join Date
    Apr 2012
    Location
    overseas
    Posts
    50
    I test fitted H&R 20mm adapters/spacers on each side today. for first on fronts - now the front wheels clear the C5 calipers
    so I tried the 20mm spacer on the rear and it looked like this:
    I think it looks okay and clears the frame now - but I think I want 30mm spacers now :D just added some washers to simulate a 30mm spacer:
    Please note there's no weight/interior/doors/engine in the car so thats why the suspension is pretty high right now LOL
    oh and here's another cool shot (with 20mm spacers):
  8. #78
    BangShifter 1badmonkey's Avatar
    Join Date
    Sep 2008
    Location
    Atlantic, Ia
    Posts
    913
    sweet car, I love the dash! I have a narrowed 59 impala dash in my 49 chevy.
    are those spacers hub centric?
  9. #79
    Join Date
    Jan 2008
    Location
    Woodinville, WA
    Posts
    11,979
    how much spacing will your rotors give you?
  10. #80
    Join Date
    Apr 2012
    Location
    overseas
    Posts
    50
    thanks! yea the spacers are hub centric. I used some spacers to simulate a brake rotor. a rotor is about 7mm thick.
    today I cut my rear fender lips a little. stock lips are about 1" wide.
    I half cut them and will roll them later to clear the tires.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
