emission testing
  • A/Fuel
    • 4520
    #46
    It's a nice 20 mile drive through the country, and I just pull right up in line and leave it running.
    Originally posted by TC
    • anotheridiot
      • 1922
      #47
      good luck.
      Pisses me off they have you turn the car off in Chicagoland.
      I always wondered if a couple things would work......
      If it doesnt pass, take a propane torch with you and get the converter glowing and go back; or find a can the size of your last exhaust pipe, cut a smaller hole in it to keep more heat in the exhaust.
        #48
        Originally posted by anotheridiot View Post
        good luck.
        if it won't pass, it's so fubar it needs attention anyway. Seriously, even in Dallas, if it's running right it will pass.
          • 32252
          #49
          don't plug the tube - it's an air intake so the cat works more efficiently... at least that's what I was told on my 93 Chev truck... true or false, it passed so I was golden
            #50
            the tube isn't completely necessary, it's there in case you have an air pump. If you don't, leave it capped.
            How'd it do?
            • A/Fuel
              • 4520
              #51
              How'd it do?
              The tube has a cap on it out of the box. I'm going in Tuesday to try it again....
              I was just looking through the info they gave me and adding up my reciepts and I'm about $25 from the waiver anyway. I think this should do it though.
              • A/Fuel
                • 4520
                #52
                I had it tested this morning again and I guess catalytic converters work. This time on the HC it was 0.65 the CO was 0.00 and the NOx was 0.87
                I am kinda supprised it tested as low as it did, unless it was a miss-print or something.
                  #53
                  Excellent - mission accomplished. I hope the tune up and new O2 help it use a bit less fuel too.
                    #54
                    That doesn't surprise me at all. Catalytic converters work.
                      #55
                      Right on Squirrel. Other than starting grass fires, I don't have a big problem with replacment cats on street cars that have to have them.
                      A/F - Nice!
                        • 28679
                        #56
                        Good job! Glad that worked out for you. I keep the cats on my DD's no matter what - the Buzz Bomb is the only car I have ever removed one from.
                          #57
                          Or you could get old cars....none of that nonsense applies to cars from the 50s
