It's a nice 20 mile drive through the country, and I just pull right up in line and leave it running.
emission testing
good luck.
Pisses me off they have you turn the car off in Chicagoland.
I always wondered if a couple things would work......
If it doesnt pass, take a propane torch with you and get the converter glowing and go back; or find a can the size of your last exhaust pipe, cut a smaller hole in it to keep more heat in the exhaust.Comment
if it won't pass, it's so fubar it needs attention anyway. Seriously, even in Dallas, if it's running right it will pass.Originally posted by anotheridiot View Postgood luck.
If it doesnt pass, take a propane torch with you and get the converter glowing and go back; or find a can the size of your last exhaust pipe, cut a smaller hole in it to keep more heat in the exhaust.Flying south, with a flock of bird dogs.Comment
don't plug the tube - it's an air intake so the cat works more efficiently... at least that's what I was told on my 93 Chev truck... true or false, it passed so I was goldenDoing it all wrong since 1966Comment
The tube has a cap on it out of the box. I'm going in Tuesday to try it again....Originally posted by Beagle View Postthe tube isn't completely necessary, it's there in case you have an air pump. If you don't, leave it capped.
How'd it do?
I was just looking through the info they gave me and adding up my reciepts and I'm about $25 from the waiver anyway. I think this should do it though.Originally posted by TCalso boost will make the cam act smallerComment
I had it tested this morning again and I guess catalytic converters work. This time on the HC it was 0.65 the CO was 0.00 and the NOx was 0.87
I am kinda supprised it tested as low as it did, unless it was a miss-print or something.Originally posted by TCalso boost will make the cam act smallerComment
That doesn't surprise me at all. Catalytic converters work.My fabulous web page
Or you could get old cars....none of that nonsense applies to cars from the 50sMy fabulous web page
