My Rampage... Cruiser/Drag Week Car
    #46
    Nice progress. Pictures please. I don't read the articles I just look at the pictures.
    • MR P-BODY
      • Apr 2012
      • 2359
      #47
      Well I got most of it built up today... I'll put the pan on
      tomorrow and prime it to see if the oil pressure is what
      I'm looking for... if all is well I'll drop it off Monday to
      have it set up on the dyno... Tuesday we should be
      beating on it and find out some numbers... as soon as
      I button up the engine I'll take a few picks.... I think
      I'll take 2 carbs to the dyno session... a 850 DP and
      a 1050 dom... just for fun... with the 4150/4500 adapter
      it wont fit under the cowl hood but I can machine the
      intake if I want to so it would mount
        • 32249
        #48
        it is an acceptable reason to put a taller cowl on the car
        or to parody a saturday night live - needs more cowl bell
        • MR P-BODY
          • Apr 2012
          • 2359
          #49
          If it makes that much more power, believe me.... I will make it fit...
          I had to machine a couple of manifolds to fit the 4500s... one is
          on my race car.. that one is e-85 on a 405ci... I've got one thats sitting
          in the shop but its a gas 1050(thats the one I'll take with me to the dyno)
          • MR P-BODY
            • Apr 2012
            • 2359
            #50
            Here's a pic of my engine... this is a 418ci SB mopar..
            W-5 heads ported by me... flows 310 @ .700
            cam is a solid roller 105 lsa, installed at 103, .640/.640
            260/270 at .050... TD rockers.... 10.9:1 compression
            this whole engine was built with stuff I had laying around
            the shop except for the pistons which are Diamond... so
            for being a throw together engine its starting to cost me
            more than I figured with the issues I had... if it makes 550 hp
            I'll be fine with that.. the engine guy thats helping with advise
            says it should make 590hp with no problem... maybe so but all
            I need is 525 to 550
            M-1 intake with a 850DP...
            When I was moving pics some how my race car got in
            this post and I havent figured how to delete it on this post
            oh well... now you get to see it also
            • MR P-BODY
              • Apr 2012
              • 2359
              #51
              Well its ready to go to the dyno...I'll have to call tomorrow and see if their schedule
              and mine can come together this coming week ... I'd like to drop it off Tuesday and
              run on Wednesday
              • MR P-BODY
                • Apr 2012
                • 2359
                #52
                I ran it on the dyno but had problems.. it lost 100 ftlbs of torque in 3 seconds on
                the second short pull.... ran a first short pull to 4500 rpm and it made 463 hp
                468 ftlbs torque and then it started eating itself up on the next pull, it was down
                the 100# so I pulled the filter and seen metallic in the filter.. so I pulled the pan
                and 4 rod caps and a main.... they looked fine other than some of the partials
                that got embedded but really nothing... I told them to pull it off the dyno and
                I'd pick it up to take home... well I picked it up today and torn it down... seen
                scratches in 2 of the bores but that was it... cam bearing, rod and main bearings
                were fine(some embedded partials again)... I even had one of the engine builders
                stop by my place to take a look .. he was stumped also... we have no idea where
                this alum is coming from.... I cleaned that block 3 times before I assembled it...
                all I can do is hone the cyl and CLEAN it again and start over...... I have no clue
                • Thumpin455
                  • Jan 2010
                  • 4753
                  #53
                  Hope you get it figured out. The last 455 I built ended up getting torn down, everything honed again, and put back together. It got something stuck in the ring lands that started scratching a couple cylinders. No idea where it came from, lucky thing I found the scratches in the cylinders.
                  Is it the thrust bearing by chance? Only other thing that crosses my mind is cam bearings.
                    #54
                    Did you have a hole go away on you? Did you get the dyno sheets, complete with egts?
                    I'll throw away any political correctness here and say, as we used to before all the harassment training, this car is "tits."
                    I like everything about it.
                    Run it at Bonneville. There are so many soft records in modified pickup that you're bound to get a couple of records.
                    • MR P-BODY
                      • Apr 2012
                      • 2359
                      #55
                      no not the thrust bearing... it looks like new
                      No I didnt bother with the dyno sheet on the 2 partial pulls but it should make 600+hp
                      and about 550 tq based on what was seen on the short pull.... all I really want is 550 hp
                      so I think I have that covered
                      thank on the car.... never gave it any thought of running Bonneville.... but would be cool
                      to have a record
                        #56
                        Bummer you can't convert a FWD to a RWD and fit in the mmp categories.
                        • MR P-BODY
                          • Apr 2012
                          • 2359
                          #57
                          I dropped off another block today to have decked... everything on
                          it checked out good just needs to be decked and I'll put the same
                          parts on this block and have the original block bored to fit a larger
                          set of pistons... should be ready for pick up on Tuesday ... have
                          to clearance the bottom of the cyl for the stroker... just a minor
                          bit of grinding
                          • MR P-BODY
                            • Apr 2012
                            • 2359
                            #58
                            bit of grinding
                              #59
                              did you ever figure out where the metal came from?
                              • MR P-BODY
                                • Apr 2012
                                • 2359
                                #60
                                Still no clue... I've looked over the heads but didnt see anything but I'm still
                                gonna tear them down to look better..... but I dont think thats the problem
