My Rampage... Cruiser/Drag Week Car
  • MR P-BODY
    • Apr 2012
    • 2359
    #241
    I did a compression check today on the W-2 in the race
    car and like I figured its a sorta low compression
    set up... 160 - 170 cranking pressure... even the oil
    pressure looked good during cranking.. I pulled that
    engine out and its on the stand for a freshen up now...
    I'll give it a once over tomorrow to see what it needs
    and order parts... then I'll pull the engine in the
    Rampage.. hopefully I can be back on the road in a
    week or two max.... This is a smaller engine but will
    rev higher... this is a 395ci and the engine in the Rampage
    is a 418ci... so far the 395 is looking good... I MIGHT even
    change it over to a hyd roller... that would come close to $900
    but I will see once I open up the W-2 tomorrow
      #242
      Can't wait to hear.
      • MR P-BODY
        • Apr 2012
        • 2359
        #243
        I pulled one head
        off the W-2 this evening... all the TD rockers look
        like new.. the roller lifters are in great shape and
        the pistons and cyl walls look great(on the one side)..
        I'll pull the other head and the pan tomorrow.. I
        measured the lift on the cam.. its .030 less than
        the W-5 engine but thats fine... the pan on this one
        might get cut down.. I'll see if I want to swap pans
        or not... so far it looks great.. and I wont have
        to buy anything.. I have a set of new rings for this
        bore and I am pretty sure I have a set of bearings
        • MR P-BODY
          • Apr 2012
          • 2359
          #244
          I have the W-2 engine all apart and it looked great inside.. this engine
          is a partially filled block... I found another block in my stash but I decided
          to go ahead and use the filled block.. its been a proven engine for years
          so I ordered up the parts to do a freshen up.. I got the parts today so I
          starte cleaning the block and the parts .. they are ready so tomorrow I
          will start assembling this engine.. I also ordered a oil cooler with a fan for
          this filled block.. I'll have the cooler fan on a temp switch so I can set it to
          what I want.. I'll also put a temp robe in the oil pan drain plug to see whats
          happening there so I can set the temp switch to the right temp... either tomorrow
          or Monday I'll start pulling the engine out of the Rampage... I'm hoping to have
          this all back together by the weekend at the latest
          • MR P-BODY
            • Apr 2012
            • 2359
            #245
            I ran into a couple of issues in my 395ci.... so I started from scratch... I used my
            stock TA 340 block(stronger than the normal production 340 blocks)... had it bored,
            decked, mains line honed, hot tanked... used my 4" stroke crank from the engine that
            was in the Rampage .. I had a issue on the W-2 heads from the 395ci engine.. seems
            that all along I was running a long valve head and a standard length head... the standard
            length head had lng valves in it and created some bad rocker geometry... well I had 2
            brand new long valve heads still in the box, so I grabbed one and ported it to match the
            other long valve head so I now have a matching set...I had the order new pistons to fit
            the deck height on this new engine( I didnt care because I wanted to start fresh)... got them
            in a few days(its good to know the owner of Diamond Pistons)... I assm the bottom end and
            everything looked good... then now that I'm running the W-2s I had to use the W-2 intake off
            of the 395ci.. no big deal, its all porte to match the heads... when I set it on for mock up it
            was way too narrow.... I ended up stacking 3 sets of gaskets to make it fit... I glued them all
            together so it was like running a thick gasket... well it was finally finished and I got it in the
            Rampage... I didnt feel like running the remote filter on this engine but I couldnt get the filter
            on with the headers in place... thank God I didnt have the engine all bolted in... back out it
            came so I could cut a access port in the inner fender well... got that done and put the engine
            back in... checked to make sure EVERYTHING else looked good and had access to everything
            that MIGHT need to come off and yet keep the engine in the car... got the engine all buttoned
            up and gave it the first fire up... fired right up in a few seconds... checked the timing and set
            the carb... let it all warm up and shut it down and gave it a once over... all looked good.... I
            tok it out for a ride down my street and it was running nice... gave it a few WOT runs and just
            put a few miles on it.... this was about a week before we would be leaving for DW... the next
            day I used the Rampage to run over to the paint store for a few small things I needed to finish
            up on the truck.. ran great going over there... no oil coming out the pipes, temp was holding
            real nice... I got my stuff from the store and headed home.. all was running nice UNTIL I came
            to a stop at a stop sign.. it took off as I rolled into the pedal but the trans wasnt shifting.... I
            tried a few thing but it wouldnt shift out of low/first.... I finally got home and started checking
            things like the shifter and cable adjustment... that was fine.. all I could figure was the governor
            was broke/stuck ... the problem is... if I want to pull the tailshaft housing I have to pull the engine
            and trans(no room to pull the trans or tailshaft housing... well after I talked to a couple of buddies
            that are trans guys they both said the same thing I was thinking.... so being that I was a bit PISSED
            and I said to hell with it... I took it out on the road and gave it a couple of 8000 rpm runs and on the
            third one it started shifting and since then its been fine... I did change the fluid and filter but so far
            its fine... that was 2 days before we were to leave on DW... so with no testing and that last issue I
            decided to leave it home and just ride with my Buddy Dale(Qick52).... we had a great time on DW in
            his 52 and he was in the 32 field for DD but he red lighted in the 2nd or 3rd round ... when we got
            back home I took the Rampage out for a short run and it was fun to drive it again... a couple days
            later the wife and I headed up to our other house for 2 months of hunting... just got back again... I
            would like to get her out for another putt before its really winter... we will see..... sorry for the novel
            but this was the short version..... of what REALLY happened
              #246
              Good to hear from you and that you are driving it.. Kinda a bummer you didn't get to take it on drag week..
              • MR P-BODY
                • Apr 2012
                • 2359
                #247
                Yeah I was REALLY bummed out about not being able to run my own
                car this year... I backed out on Aug 15th... I had set that as my do or die date...
                when I first got the new engine back in, it was with the W-5 heads that I had
                on the previous engine... well it was still blowing oil out the tail pipes... I had
                the intake off about 6 or 7 times thinking it was the intake gasket... finally I
                had to say that wasnt the problem.. so I pulled the heads off and went with the
                W-2s and had to port the one head to match... then the gasket issue on them...
                but now its doing fine... I'm thinking about taking it out tomorrow to do some
                shopping... but I dont like leaving it by itself for long... short times isnt too big
                of a issue... but I guess I better get use to it... LOL
                • mopar57
                  • 172
                  #248
                  great news to hear it is running well, plenty of time to get ready for DW next year, and enjoy it in the mean time!
                  • MR P-BODY
                    • Apr 2012
                    • 2359
                    #249
                    Thanks..... yeah I'll have plenty of time to test it.. I know I need to change all 4 coilover springs..
                    the fronts are too stiff and the rears are a little soft... I'll go up on the rears by 10# to 20# and the
                    fronts need to be softened up by quite a bit.... I have to get this on the scales to see what the front
                    and rear bias is... based on the weights I was figuring (2800-2900 lbs) I would say I'm close but the
                    bias to a little off... the front isnt as heavy as I guessed and the rear is a touch heavier... which should
                    be good.... I will see shortly.... I think this engine is making a touch more power than the first one I
                    dynoed but it is what it is
