next mission
exhaust and perfect..has not happened for me and the little sube. the bigger and better I make it, the more flow..the dumber the exhaust seems to get. rather than cramming the engine with its own ass.. I looked for free advice, be it inadvertant through you tube.
was watching a porsche 991 getting dismantled..of course they be the genius of boxer exhaust, many years of power and different sounds..draft cams, injections, turbos..
I spotted these mufflers or resonators or cats..whatever they are, they are at the side height of the cylinder heads. must be a huge relief for a boxers design.
epiphany. I can’t go to side of engine to add a box to gain some height..but I do have room behind th eheads, to make something similar, one for each header. it may be a spot to do a crossover under tranny as well, allowing for full duals out to the side. As things came together nicely this year, the focus can be an extra..I choose exhaust. it is already all mine..needs more thought. thanks porsche.
that big muffler i could not use..it is in my parts pile, looking new. 3 weeks or less use. I will chop that in half and make a similar gadget to the porsche..that is plenty of height, chopped in half, plenty of room behind each head, one half each.. would only need a small sheet to seal in the halves, make my own resonance while open.
watching some local racing, a view of winterport dragstrip through an rx-7 windshield, the sound of an LS, and sight of a shaker hood scoop rocking to the right...seems so new. LS, little car, etc.
I was there almost 20 years ago. 1/8th mile still seems useless. the rx-7 being closer to a motorbike with a v8 makes sense in a short run..my chevelle buried the right rear bumper, spewed fuel, and never hit third...all that for a cough halfway down the track and 70 something miles an hour.
part of learning the little sube is learning how to drive a four banger. this sounds like a motorcycle now, caught on recently to ways that keep power rowing gears..instead of the truck like life it has had for 26 years.
the stage 1 clutch allows for not letting off throttle entirely between gears. the boxer freakishly loves that gyro'd momentum uninterrupted. I learned that unintentionally very recently. I would guess it catches my slug old chevelle times in a crazy proportion of little power to the work getting done. I'd be proud if it did...its even got bigger tires than my chevelle did.
my real interest is a result of an event years ago, around 90mph..the boxer gained another world. assumed it was heads draining to the wind. the gear calc has been right all the way to my only speeding ticket...in an 84hp subaru. Funny life I lead. all those years..my first speeding ticket is with an 84hp subaru engine. A 135mph interests me at loring more than an eigth mile.
laugh if you want, but am going to find some more flow stuff about porsche and modern day. I have injection cams on a draft...some challenges.
some things learned getting a larger diesel type push...
diesel being the keyword for a need of high octane. my hillbilly learning curve I guess. I have never exceeded an octane rating until the little sube. maine only has 90. I learned of this with a another subaru owner, big spender. an overseas version..world of trouble. snappy twacking headers is about as good as it got. I followed suit with custom stainless, mandrel in the very hot zones..unpredicted was shredding header wrap. I am on my own.
this one is small, alot of small things and time lengths to monitor. 90 octane took a long time to soak the system. that was a nice gain, it will get away with it..
exceeding air fuel volume by a bunch, the large header, breaking fire up below 3k rpm..
all those things are more than gimmicks for this old ricer.
exhaust needs a guru, as subaru has been freakishly insane with piping since the ea82 came out, and years following..going on 30 years now. There was a calm spell with a 2.2 liter and equal header, funny enough, those are the most retained value when looking up subes for sale. Can you imagine? An equal header, even cheaper to make, kept the value of the car and a few more miles going on 20 years later...companies are damn stupid sometimes.
Subarus. It's like wondering what experimental monkeys did every time I pop the hood of an oem version..the owners are the sane ones going for straight pipes and window rattlers.
not to slam subarus EJ generation entirely.. I only narrated its end when it began. I would try a 2 liter if it proved to be in a rare chassis. there is some jacked up ones, thumpier than the others. to me, that marked the end of the overlap of ea82 engineers and what they believed was manly enough.
It truly went to hell after that. early 90s. Not much choice for boxer engines and being real with them. I mention it here..no odder than the desire for an ohc six cyl, something america did not make much of either...or an isuzu diesel in an s15 pickup..there is some odd sprites with a trait of something really desirable. Stereotypes of origin is the only thing to contend with.
