awesome fuel filter
finally.
found this at mercedessource.com . kent bergsma wanted a fue; filter for his mercedes like I do for anything. Screen mesh, cleanable. the 5/16ths version can get a coupler to bolt right up to the rochestor fuel inlet. No a/n runaround stuff needed.
pricy, but the pro filter I am using is a runt for most of the price of this stainless smesh version..which I have been hunting down for a long time.
todays saga is an exhaust seated and an alternator that sprung to itself. Triggers charge light, makes a noise..almost like a supercharger. shut off key for a minute, back on, and no charge light..overdid the little buggy to a static snap, charge light trigger is a fake. Just another supercharger noise coming from under the hood of the old sube.. this means it is willing to regulate what is needed, but got hot to the uprising of left side header finally doing its job. this is a much more than once event for me and this one. my loyale did it often. A long seating process once taking out the engine, or manifolds, wiring, etc. I did all those things to trigger an eventual event dialing in. the difference this time is a giant exhaust, a real fan. the next start its like it had to take out its old memory and go with the new...all while not even being a computer. Solid state einstein. With this change is an even larger runtime.
this reminds me to get back to the other alternator rebuild. the one in it now is quite a worker..I ponder just a oily finger on the stator or rotor this past summer sending a vibration as it warms up. Quick static snap of new work on the clean spot finding a way to ground. It always wins. last night had below freezing for six hours. most likely its biggest cooldown yet. As cryogenics works aluminum, it shed something inside the case unknown to human eyes...blows it out eventually. I like this time of year for this engine and parts..it is like a sterilizer. tells me what the summer did. The welding by muffler this summer double layered the chassis where it used to get warm..I bet it found another place to send 60 hertz, made itself too big for a short time..steel dialing in, and aluminum shrinking..makes a potent runtime.
this engine is proving to be a very nice one. Have not heard any better for an ea82.
edit2:
further examining revealed the belts got too tight. the double belted engine, have to be careful there. the little fan brings alot more heat across to the cold side of radiator..physic of the fan..this some how tightened belts. probably a backwards rubbber, like heatshrink to wires.
been there with this, just going to loosen and drive.
a really unique runtime this one. sounds like exhaust is airing at all times, like a turbo that never stops spooling .. at just 700 rpm. the decibal exit is that of a v8 with flowmasters..that never ending sound of flow, but the boxer erases cylinder noise.
I can get that boxer cylindrical noise at 1500, only due to less than perfect idle to part throttle bridge...else it would be rather turbine like at all times.
I'll have some fun trip someplace after inspection and registration stuff out of the way. maybe get a vid or two
finally.
edit2:
