comming tomorrow
Pintoboy77 Torino Project (Lost in a restoration black hole)
Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!") -
snowing when I just took Tammy to work..Patrick & Tammy
- Long Haulin' 2008, 2009, 2010, 2011, 2012, 2014...Addicting isn't it...??Comment
17 degrees here this morning - I shoveled about 6" out of the driveway here yesterday kicking myself for not bringing the snow blower home from the shop.
Yesterday afternoon I tore into the front end of the truck - ball joints on trucks with 200k on them flat out suck - I got the knuckle off and will take it and the axle shaft in to a shop that can press the old joints off and new joints in - the rear bearing of the hub is shot, the 4x4 hub lock needed cleaning and grease, and both axle shaft grease seals were shot - thankfully the driver side wasn't as bad - I need to get the seals replaced on both sides so the auto 4x4 hubs will work right. My back hurts!
Good luck with the plow Greg - too bad you're so far away - I'd hire ya to plow here! ;-)There's always something new to learn.Comment
went to change the tires on the brown T/A. they have these special wheel lugs that need a special lug wrench.
finally found a tool at sears. basically like those sockets for rounded nuts. it was expensive and it tore up the lugs, but who cares. it's not like i'll use the lugs ever again. they are now on the metal pile.Bruce, Sanford, Fl
welcome to my worldComment
Good luck on those they can be a real pain.Originally posted by milner351 View Post17 degrees here this morning - I shoveled about 6" out of the driveway here yesterday kicking myself for not bringing the snow blower home from the shop.
Good luck with the plow Greg - too bad you're so far away - I'd hire ya to plow here! ;-)Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
A friend of mine did the same thing he put 20 lock lugs on his car and then lost the key and then he brings it to me to get them off. I told him he had more in the lock lugs than he had in the wheels and tires.Originally posted by cobra View Postwent to change the tires on the brown T/A. they have these special wheel lugs that need a special lug wrench.
finally found a tool at sears. basically like those sockets for rounded nuts. it was expensive and it tore up the lugs, but who cares. it's not like i'll use the lugs ever again. they are now on the metal pile.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
Allen if you would like I could send you some of are cold and snow and help kill them off.Originally posted by cstmwgn View Post"I'm Agreeing with you on the current overpopulation of the Wapsipinicon river official bird(mosquito)... "Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
I think that Allen got it...Bruce needs some though....Patrick & Tammy
finally found a tool at sears. basically like those sockets for rounded nuts. it was expensive and it tore up the lugs, but who cares. it's not like i'll use the lugs ever again. they are now on the metal pile.Yeah, but Bruce got a new tool so he will be alright. When his brain thaws, he will get the other statementOriginally posted by silver_bullet View PostI think that Allen got it...Bruce needs some though....
FKA Redragtop
(formerly known as)Comment
ooooooooooooooo That's Harsh...Patrick & Tammy
Had to go to work today I got an emergency call that one of my customers air compressors was down and I had to get it back up. Then I plowed the snow at the shop while I was there so not much got done on projects.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
About to head to the shop and get started on something I have taken on more projects. The one thing I said I was'nt going to do this year I'm a sucker for a sob story.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
happy new year bud...let it be a great one!!Patrick & Tammy
