That's gonna be hell on bushings.
you've completely gutted, resuspended, repowered, and repainted your car. You can't measure for 2 pieces of aluminum rod and drill a hole in the middle of them? Oh John, this is the moment when Ford thinking took over - I'm so sorry for you and your loss of abilityOriginally posted by milner351 View PostI think that is why the crites kit comes with aluminum bushings for the frame side ---- anybody got a source for aluminum bushings?
Doing it all wrong since 1966Comment
Touche
- I don't have a lathe, and my local metal supplier doesn't have much in the way of solid bar stock, especially not aluminum, but I will look into it! (and I have a somewhat local friend with a lathe)There's always something new to learn.Comment
If you're going to use a solid bushing, you might as well, just weld plates on both sides of the frame rail and just drill a hole for the bolt!
Or drill a big hole and weld a piston pin in there.Last edited by BBR; August 2, 2012, 01:46 PM.Life is short. Be a do'er and not a shoulda done'er.
what is the OD of the bushing? what size bolt?Originally posted by milner351 View PostTouche
- I don't have a lathe, and my local metal supplier doesn't have much in the way of solid bar stock, especially not aluminum, but I will look into it! (and I have a somewhat local friend with a lathe)Doing it all wrong since 1966Comment
How about Delum bushings? I think it would be a little more forgiving then the aluminum. Nice job on the brackets! The road race guys play with the front bushings to increase anti roll characteristics.TomOverdrive is overrated
Urethane, Delum, Delrin would be a good option, I think Energy suspension makes them for Gen 1 mustangs - which I'd have to trim to fit since they have 2.5" springs and mine are only 2" - no biggie.
Here's what NPD has in stock since they're just up the road....
what's "Midolyne"???
We carry classic Mustang parts & accessories,Camaro parts & accessories, Chevelle parts & accessories,El Camino parts & accessories, Malibu parts & accessories, Firebird parts & accessories, and Trans Am parts & accessories as well as Ford truck parts & accessories
The bolt is 9/16" the OD of the busing / ID of the frame tube, I'd have to measure.Last edited by milner351; August 3, 2012, 07:11 AM.There's always something new to learn.Comment
Those offset shackles look good. I've often wondered about doing that on the 68 Coupe I have to allow use of the mini-tub I did w/o going to a coil over setup. I just didn't have a clear idea of how to do it. Thanks for the pix.Rich
Drag Week Survivor 2009, 2011, 2012, 2013 - 2nd Place - Pro Street N/A, 2017Comment
Getting lots of hard time consuming work done John! Do you have an estimated time of it moving under it's own power?Escaped on a technicality.Comment
As soon as possible, which won't be soon enough - Rhonda is traveling allot again - so I'm missing out on some weeknights. I'm trying to make the most of the weekends, and have some friends helping where they can.There's always something new to learn.Comment
Sometimes, your calmness makes me think you are farther along than you let on and are just teasing us with the progress pics... hahaLife is short. Be a do'er and not a shoulda done'er.
I'm not anywhere near as far along as I'd like to be, but I'm doing my best.... the car will be no where near "done" for DW, but I hope it will be atleast as reliable as it will be ugly.There's always something new to learn.Comment
You should totally get a spare bumper to have hanging on one side and dragging pavement on the other
