Transmission linkage hitting the headers. Very badly at that. I want to keep it column shifted but its going to be a pain because the tri-y headers have the back tube connect into he collector where the column linkage should be.
Doug's Tri-Y's were designed for a different chassis, early chevelles. Check their website for notations about fitment issues. Their Impala headers only work on with cars without power steering which idiotic because 90% of Impalas had power steering.
these are g-body headers, came off a 78 malibu. Which most g-bodys are cloumn shifted. maybe they think non-ac, powersteerin, floor shifted race cars run headers.
When it comes to headers for Gbodies there arent to many choices.......I used Flowtechs from Holley on my Regal(406 sbc).....I been pretty satisfied with them but if I had to do again I would have them ceramic coated to maintain a nicer finish on them......they are designed to fit around the passenger side bend on the G-bodies......I have no column shift linkage to compare to since it was gone when I aquired mine and I installed a console with a B&M Magnum pistol grip in it.......
That steely eyed look I had behind the wheel was me trying see..........
my 85 monte carlo had a different bracket setup than my older cars have had. One bolted to a hole in the drivers side front of teh block than my current 74 400 doesn't have. Im lost as to how the brackets were for one, i have serious memory issues. I've got Tri-Y headers that turn down and back as soon as they come out.
I think the older bracket setups had the bigger ac compressor
Now on my 400 sbc I got a serpentine set up off of a V-6 Blazer and bolted it up after sand blasting/etching primer/paint..............
I grabbed everything off the Blazer.......a/c, power steering, alt, pulleys, tensioner, and brackets and bracing.........oh here how mine sits....................before
After spring cut by BBO Javelin on here............
No I didnt touch the back but it came with air shocks on the back so I let out some air when Jake (BBO Javelin) cut the front springs on it for me.......my back tires are 255/60-15 Mickey Thompson S/T..........
Im working on making mine handle better......I just recently scored a 36 mm sway bar off 1987 Firebird(non-Trans Am) but it had the leather pouch on the passenger side but no fire chicken on the hood..........anyways I plan on getting to Jake's to sandblast and have it powder coated to install......will pick up the Energy Suspension end links and 36 mm mounts to install it..........
Mater what your plan on your cars?
those two are long gone sadly the 82 Grand Prix LJ Brougham Diesel (had a 350 oldsmobile when i got it) was stolen from my high school parking lot back in 2005 and the monte carlo CL had no trunk floor or rear frame rails some guy bought it to turn into a SS clone have not seen the car sense
