Love the gas station shot. Car has a real muscle car stance to it. Really dig it.
1985 Monte carlo
How much will new spribgs settle? I cut 1/4 coil off new moog 5596s. And installed them, and it looks like a gasser.
Si vis pacem, para bellumComment
1/2 inch to an inch depending on rating .. I'd drive it around for a while and if not low enough by spring cut more offComment
Remember how many times I pulled the springs in and out of my Impala? You can cut out more, can weld coils back on.BS'er formally known as Rebeldryver
sigpicComment
Yeah, was going to drive it today, but didn't have brakes, need to bleed them and was alone so fenced instead.Si vis pacem, para bellumComment
V6 springs? What application is the 5596? I put stock MCSS springs in my Malibu and it was nose high. Cut 3/4 coil off them and it sat nicely with zero gap from 26in. tall tire to the fender. MCSS springs are 5606's or so, which is stiffer than your 5596's. In the blind, I'll say cut another 1/2 coil off, but I like running a stiffer spring.GM G-bodies, because I can't afford a 69 Camaro.Comment
5596 are non AC v6 Malibu springs. either it settled some overnight or im drunk, its an inch or two above a 26in tall tire.Si vis pacem, para bellumComment
not touching that,, hehe, give it some more time...Originally posted by kyhunter89 View Post5596 are non AC v6 Malibu springs. either it settled some overnight or im drunk, its an inch or two above a 26in tall tire.
car looks killer, you've done well since you got it.. you send the yellow bomber wagon down the road?Comment
Yeah, horse traded for a 4x4 sonoma, to a grand prix to the white crown vic.Si vis pacem, para bellumComment
yeah my monte looked like a gasser for about 2 weeks until the springs settled
i used 3.8 regal non-ac springs in my 4.3LOriginally posted by Remy-Z;n1167534Congratulations, man. You've just inherited the "Patron Saint of Automotive Lost Causes" from me. No question.
75Grand AM 455:Pissed off GrandMA, 68 Volkswagen Type1 "beetle":it will run some yearComment
