Me n Ethyl
    • 32252
    #121
    that air box is a work of art (okay, work of CNC but still it's art)
    • wrp
      • Jan 2011
      • 469
      #122
      Thanks, I nearly left my wife when I saw it. We've been running a homemade solution for two years but when I saw this I had to get it. I'll be sleeping in the back yard for several more weeks.
      • wrp
        • Jan 2011
        • 469
        #123
        Was out flirting around with my new sweetie today.
          • 32252
          #124
          are you going to coat or paint the inlet pipe as well? and yes, that will look excellent when it's installed.
          • wrp
            • Jan 2011
            • 469
            #125
            Currently haven't discussed the pipe. Obviously will need to build something new. At this point powder coating it would end up with a lot of black so I am thinking polished aluminum. Wish I knew a carbon fiber fabricator that could whip up a tube without me having to use my grandkids for payment.
            • wrp
              • Jan 2011
              • 469
              #126
              More blood
                • 32252
                #127
                I hate it when I spring leaks, then have to clean it off my car.
                • wrp
                  • Jan 2011
                  • 469
                  #128
                  Just pulled the trigger on an FTI Stage 5 TH400 and all the supporting mods. Should be in next week and hopefully have the car running again within the next two weeks. Knew I should have done this in the first place and feel really good about the decision.
                    • 32252
                    #129
                    no more third pedal? make sense, actually.
                    • wrp
                      • Jan 2011
                      • 469
                      #130
                      Yep, figured if it took over 6 months to put it together then I would be screwed if I had a problem.
                        #131
                        Curious to know if you have a hood in the future to "hide" that powerhouse.
                        • wrp
                          • Jan 2011
                          • 469
                          #132
                          This is the rough cut. I have a really good Hot Rod fabricator who is going to smooth out the cuts and trim the edges with tubing in an effort to make it smooth. There won't be any sharp angles. Been held up by the transmission which I have to have installed before we can finish it. I think the new intake may eliminate some of the extra cut out to the side for the intake tube.
                          • wrp
                            • Jan 2011
                            • 469
                            #133
                            The 6 speed came in today. I am a little sad I won't be using it but I am more and more stoked about the FTI build. Here it is. Greg already has parts en route to Texas.
                            RATED TO 2000 HP
                            CUSTOM DIRECT DRUM WITH PRO MOD SPRAGUE,
                            HIGH PRESSURE PUMP
                            BUSHED CENTER SUPPORT
                            VASCO INPUT SHAFT AND LARGE SPLINE DRUM
                            BILLET FORWARD CLUTCH HUB
                            ROLLERIZED OUTPUT SHAFT
                            5 CLUTCH INTERMEDIATE PACK
                            HARDENED STEEL ALLOY MAIN SHAFT
                            HIGH FLOW FILTER
                            FULL MANUAL REVERSE PATTERN TRANSBRAKE
                            248 LOW GEAR ASSEMBLY
                            SSW93B 9" STEEL STATOR DIODE PERFORMANCE CONVERTER
                            SHIELD CARBON SFI SHIELD
                            SPEEDO KIT
                            SHIFTER B&M QUICK SILVER 3 SPEED SHIFTER
                            FP319 Flex Plate, True Billet fits GM LS-1 thru LS-8, 168 tooth count, internal balance
                            MISC PLATE TO COVER 6 SPEED HOLE FOR AUTO SWAP
                            CROSSMEMBER FOR TH400 SWAP
                            COOLER TRANS COOLER AND #6 LINE WITH ALL FITTINGS
                            • wrp
                              • Jan 2011
                              • 469
                              #134
                              Went out and saw the actual T56 today. the polished shaft looked incredible. Actually saw the build sheet on it.
                              Picture of the sheet didn't come out but it was essentially as follows:
                              faceplated by Liberty and included
                              Liberty Billet interlock
                              Liberty Billet Interlock Bolt
                              Liberty Billet shift plate set
                              Gforce 2.71 ratio 9310 straight cut gear set
                              micro polished internal parts by Performance Metal
                              Bronze fork pads and shifter bushing
                              RPM modified 1-2 shift fork.
                              RPM managed the project and performed the teardown, prep, and shipping.
                                #135
                                Polished case? You know you will have to keep it polished. That means crawling under the car with your tub of metal polish and towel at least 3 times a year.
