squirrel's 57 Chevy one ton
    #46
    man , there some bad recon cranks in the early nineties , atk was real big offshoring machine work and most of the cranks failed , loads of comebacks
      #47
      the metal flat bed is fugly but a nice wood bed with some nice wood stakes it would not be awful..
        #48
        heh....that's funny Joe, have you seen pics of my 59 chevy truck from 1985-1990?
        But I've had enough of flat beds, I'll do something else with it.
          • 32276
          #49
          yay - no flatbed
          I'm all for flatbeds on work trucks.... but I've never thought they were a 'styleish' thing.
            #50
            I pulled the pan off and flipped the engine over. Neat stuff....the block is a 4 bolt main! and the three rod bearings I took out look ok, the crank is still pretty nice (can't feel any wear, mic at 2.1794 iirc)
            I guess I'll buy some 20 under bearings and change them one pair at a time, and see if the rest are ok. It's kind of a pain to take off more than 4 caps at once.
            Bearings are dated 1990
              #51
              There is something really familiar about those pics. I just can't place it.
                #52
                It's just 20 years newer
                  #53
                  check the cam bearings good
                    #54
                    yeah, and I should check the cam itself, too.
                      #55
                      The cam looks iffy, one of the lobes has pretty noticeable wear. I guess I'll see about putting in a new cam.
                      I pulled the TH400 apart today. Smoked direct and forward clutches, the plates were kind of welded together, which is probably why I was able to drive it at all. Also had a wasted thrust torrington bearing in the geartrain, and some chunks are missing from a couple planet gear teeth. I guess I swap in another rear section from my parts collection. The case looks ok so far.
                        #56
                        Since we gave the 87 Suburban to my son, I need a truck to drive, so I got my 59 extended cab re-registered and insured.
                        now I'm toying with the idea of putting this extended cab (that I built in 1994) on the 57 one ton chassis. Hmmmm......
                          • 32276
                          #57
                          dually?
                            #58
                            no, singly. I don't have any dual wheel stuff except for the old dodge parts on my Travco, and I think I can get by with singles for the stuff I wanna do with the truck.
                              #59
                              that is one very cool truck. What's under it's hood?
                                #60
                                Jim
                                your collection disgusts me, damned desert dwellers anyway.
                                Let's see guys - I'll just pull ANOTHER rust free 50 year old vehicle out of the back fourty and put it back on the road.
                                Lucky bastid!
