Dad just left to get the camper. The plan is to use a big steel frame that was laying around as a sled. Jack up the camper, slide the sled under it while keeping the front end on the trailer, set the camper down on the sled, and winch the whole kaboodle onto the trailer. Should be fun!
It went pretty smoothly. The jacks were in pretty bad shape, we got two of them to move a couple inches, and they didn't have the bracing that is needed to keep it from falling over. So we used the floor jack as much as possible, as well as some muscle. My son Steve did most of the winching. Also I stopped at home depot and got a couple more fittings so I could tie the front better, I ended up putting two straps, diagonally under the cabover area, from the bed anchors under the "wings" across to the opposite side of the trailer. This kept the front of the camper from moving forward or sideways.
In case you're wondering, the "sled" thing is my frame table....I used it to build a custom frame for a Studebaker street rod many years ago.
those winch camper lifts that you had in picture 2 work really slick if you're on a solid surface... also, you mentioned that you tied down the cabover portion - don't do that, they aren't that strong and can break quite easily.
so, just out of curiousity, why didn't you slide camper into the bed of the wife's truck?
The inside of that thing rules Jim! It might motivate me to do some more work on my POS trailer, just to keep up with the Jones' :D Namely get the propane stove working and the sink plumbed in, followed up with a legitly working A/C system.
Mighty stylish, Jim. No more sleeping in a cheap motel room for you! Looks like it's pretty complete and I don't see any telltale water stains inside (this is VERY good).
