I replaced the plug wires today. I was still running the original Accels that I put on right after I bought the car. A couple had worn through on the suspension. I also finally used an NOS AC/Delco rotor I had lying about forever.
The car is running great with the Holley, but it pings a bit under full throttle. So, I backed off the timing to 12* initial and it's 32* total.
I took it the on ramp of the freeway and using the metering light mashed the gas with the car in first. I've never really shifted this car manually before. The car moved out pretty good, but at around 3000 rpm the tires came loose, spinning. I didn't lift, but then the drivetrain started freewheeling. I think the locker let couldn't hold. As soon as I let off the gas it, it caught and started moving again like nothing happened. Strange. It did this once before according to Carl.
I did some reading on the Powertraxx Lock Rite manual and realized I never checked the clearances. I feel there may be too much play between the couplers and drivers. In the end, I may have to go to a posi.
