Heli Coil A Stripped Out Bolt Hole
    • 28692
    Re: Heli Coil A Stripped Out Bolt Hole
    I'm with Jim on this one. Works great for me w/o threadlocker. I was always worried that the threadlocker would lock the heli-coil and the new bolt into a big wad when you tried to remove the bolt down the line, but maybe it doesn't really do that. Like I said, I never tried it.
    • Ron Ward
      • 5340
      Originally posted by squirrel
      You could have done it yourself! It's not rocket surgery.....
      A more challenging operation is extracting a broken bolt.
      Or if you REALLY wanna test your mettle, extract a broken screw extractor. UGH!
      Ron
      • malc
        • 5333
        Nice job well done, I hope the other threaded hole does´nt go bad on you.
        I would have done both, just in case.
        • IndyShiftman
          • 1122
          Kind of on a related note, if you ever have a bolt that breaks off and it's not seized in, often times I'll use a reverse rotation drill and bit to drill the bolt. Then if your lucky, the broken bolt will start turning counter clockwise and you can spin it on out, saving your threads.
            • 28692
            Back in my working days, I had a set of LH drills in my Gov toolbox for this purpose. One day I came across one of our guys CRANKING on the drill press and unable to make a hole in a plate. You guessed it - he "borrowed" a bit from my box. I taught him how to make out a Purchase Order that day - one for a new LH drill bit for my box, one for a set of RH bits for his.
