Fuel Pump Inertia Switch
  • Monster
    Administrator
    • 25695
    Re: Fuel Pump Inertia Switch
    LOL !!!
    :D
    • Bigbuds1
      • 2485
      I picked up 3, so I have 2 extra.
      What are the rules on mounting position? Is under the car good? I have no trunk.
      Living the dream!
      • miketblsr
        • 771
        I will have 5 extra at the track if anyone needs them!!!!!!!
        • 1 fast evo 2
          • 181
          I was wondering if there is a preferred location to install these inertia switches?
          I was going to put mine in the trunk in-line with the fuel pump relay, do you think that is a good spot?
          • revolutionary
            • 704
            That seems to make the most sense. The factory location on those is in the trunk mounted with the red button vertical.
            • Bigbuds1
              • 2485
              I mounted mine under the car near the fuel tank. I tapped in where the sending unit harness enters the bulkhead in the center of the axle housing. :
              Living the dream!
                • 28677
                Any reason not to mount it on the roll cage where I can reach it? I'm thinking there's a remote possibility that the shaking of the track could shut it dow. The Camaro doesn't ride THAT rough but you never know.
                • jasper 2
                  I was thinking the same thing. I have a brand new one right here in my hand and just a firm shake and it trips.
                  • revolutionary
                    • 704
                    At the race this weekend, I only saw one car (the little white streamliner) that had an inertia switch problem. Guess it shut them right down.
                    • greenjunk
                      • Nov 2008
                      • 871
                      I got a push start and the car stumbles a little bit when leaving, and I got a double hit when it left from the push truck behind, the switch didn't pop, but 10 seconds later the head gaskets did :-)
                        • 28677
                        I handed them my spare but I guess they decided not to use it. I got it back at the end of the meet unused.
                        • Monster
                          Administrator
                          • 25695
                          Inertia switches SUCK !!!
                          :o
                          • revolutionary
                            • 704
                            :o
                            The bitch is building up the inertia in the first place!
                            • fahrenschnell
                              • 6787
                              :o
                              Yup.....
                              200 mph or bust.......
                                • 28677
                                #30
                                Mine worked out just fine. But then, I'm SPECIAL (like, a SPECIAL bus, a SPECIAL teacher, etc.).
