86 Mustang PITA
    Re: 86 Mustang (No clever name yet)
    x3 >
    • nesabo
      • 4288
      I needed this car to get me out of my cabin fever. setup a propane heater in the garage to work on this car.
      Neal
      • 88pony
        • 597
        Nice project, but ditch that wing. I'm right there with you on the cabin fever as well.... and it's snowing AGAIN!
        • Thumpin455
          • Jan 2010
          • 4753
          Get some insulated bib overalls, a nice insulated work jacket, and a pair of insulated boots. I only crank up the heat when I need to paint something or its colder than 10F.
            • 28707
            You Upers are insane. I won't go into my shop if it's below 50F or so - at least until the heat is in.
            • mustang13
              • 3379
              Neal, I say yes to a Painless kit. I'm putting a seven curcuit in the Pacecar. Easy Peeze, lemon squeezey. So simple, a caveman could do it.
              I got rid of the OEM key switch (locking colume not go for roadracing) but, am adding a simple on/off key switch on the dash to arm the ignition, next to the starter button (which is battery hot, to crank for oil presure) for theft deterent. Draw out on paper all the electrical systems you will have/need, it helps clear the head to sort it all out. There's alot of OEM wiring you can do with out in a type of car like this, think weight savings too. Wait till you see how heavy the stock key switch assembly is!
              Jeremy George in Windsor NY
              • horsewidower
                • 2319
                #37
                Get the Painless kit. The '80s Ford wiring harnesses are not standing up well to time. I've replaced a lot of connectors and dealt with deteriorating wiring on mine. Trying to figure out where the shorts are can be very frustrating.
                • nesabo
                  • 4288
                  #38
                  Ugly wing is off, GT wing set in its place. I need to get the mounting hardware for it.
                  I talked to the guy I bought the car from. He is giving me a roller 302 short block that he just rebuilt and some roller rockers for $0. So engine has been decided. Will pick up the engine next week. He is cleaning his garage so there may be more stuff coming.
                  Neal
                  • nesabo
                    • 4288
                    #39
                    Engine is here, may need some cleanup on the bores. he gave me a x303 cam, there is a b303 in it the engine now. The rockers are still on an engine, he will be pulling them off soon.
                    Neal
                    • BluLightning
                      Blue Cooler Operator
                      • 9389
                      #40
                      Neal, if you need a hand with anything, give me a shout. I've got plenty of time on my hands.
                      I R Bob
                      You can't drink all day unless you start in the morning!
                      2007 LH, 2008 LH, 2009 LH, 2010 LH, 2011 LH, 2012 DNF/BLOW'D UP, 2013 LH, 2014 LH
                      • nesabo
                        • 4288
                        #41
                        Thanks Bob. I will definitely need the help. Miller Lite correct?
                        Neal
                        • BluLightning
                          • 9389
                          #42
                          Yes sir, that is the going rate. ;D
                          I R Bob
                            #43
                            X303 - NICE
                            Same cam I put in the ranger 302.
                            Check your valve to piston clearance carefully if you are running stock HO pistons like I am...
                            - mine is tight by Dave's patented tin foil ball and measure technique....
                            Hopefully you can find a good deal on a good set of heads. I was totally amazed at the transformation the twisted wedge heads made to my completely stock short block in the '90 I had.
                            • 1988montecarloss
                              • Feb 2009
                              • 3198
                              #44
                              sorry for the 2nd hijack. but i like this ;D
                              • nesabo
                                • 4288
                                #45
                                Started ripping the wiring out today. Dash fought me, but i won!!! :-\. Need to drop the gas tank tomorrow so I can install the battery box.
                                Neal
