Re: Define valve float......
Do you have any valve train noise at those rpm's? I once had valve float after stabbing a cam into an engine with 150,000 miles. I'd get backfiring sometimes, sometimes valve to lifter noise at about 4000 rpm. My springs were too weak to handle it. What are the specs of your cam?
My Impala's 383 would fall flat at the same rpm, but it was a inefficient carb. I had Carter's version of the Edelbrock that was a 625 cfm. I even had the biggest jets and metering rods available. Maybe you just need a bigger carb after all. My suggestion would be Holley's 3310 750 vac secondary. Maybe someone can let you borrow one for a couple days.
I have most of the parts to build a 650 double pumper. I just need bowls and a fuel rail. Maybe I can piece it back together with some other parts and send it to you for you to try.
