Scale wind tunnel model testing
  • 98ciHemi
    • Dec 2008
    • 2425
    Has anyone here tried anything like this? I am considering trying to make a 1:16 scale clay Escort so that I can play with different aero stuff. I have limited access to a small windtunnel, and I have done wood sculpting before, so I believe that I could make a pretty decent model. Would this be an accurate way of testing? The way the wind tunnel is set up now it measure only lift and downforce, but I may be able to make it measure force inline with the car if I work on it. I also may be able to bum a fog machine to judge airflow. Any thoughts?
    • 28687
    Re: Scale wind tunnel model testing
    A couple of lads from Dayton Ohio had pretty good luck with this syatem. Their tunnel is now in Dearborn, MI. It's a perfectly viable method but is only as good as the instrumentation and your ability to accurately scale the car and the measurements. POST PICS!
    • Monster
      Administrator
      • 25718
      Sounds worthwhile Walt, go for it and report back here on your results.
        • 28687
        Anyone have a model of a '78 Camaro lying around? I'll send it off to Walt.
        • 98ciHemi
          • Dec 2008
          • 2425
          Gimme the track widths, wheelbase, tire size and wheel size and I will start working on a base for it. My plan right now is to form the bulk of the car with pine or basswood, and then lay up clay around that. To measure the drag, I will make a small air cushion table sort of like an air hockey table to get eliminate surface friction, and then use my airbrush compressor as an airpump. the car will go on a base that will ride on the air cushion and then be held back by a light rubber band. I can use a powder scale to establish the rate of the rubber band, and then use a scale to measure rearward movement of the car, and hence measure the drag of the car. If that makes sense to anyone. Downforce is easy, and just requires fixing the car to a kitchen scale and sticking it in the wind tunnel.
          • 98ciHemi
            • Dec 2008
            • 2425
            And those lads you speak of were losers. Hmmph. Bicycle mechanics.
            • Monster
              Administrator
              • 25718
              Umm, Dan, I know you have a Camaro, but Walt has an Escort.
              He wants to check out different aero stuff on HIS car.
              So, if anyone has a 1:16 scale Escort model lying around, sent it to Walt.
              • studemax
                [ Expletive Deleted ]
                • 6505
                Keep in mind you can do aero testing in water, too.
                Since water is denser, you can get good results at lower speeds.
                Just an idea, if you'd like to follow it.
                Act your age, not your shoe size. - Prince
                • 98ciHemi
                  • Dec 2008
                  • 2425
                  Hadn't thought of that. Air seems a little easier since I already have a windtunnel. I may keep that in mind though.
                  • greenjunk
                    • Nov 2008
                    • 871
                    It was my intention to do something similar to this and test a model of my camaro in it to see if I can replicate the results I learned in a real tunnel. seems like if you built your own tunnel with a couple digital meat scales you could get some sort of results assuming you had the fan to pull it.
                    • fahrenschnell
                      • 6787
                      Walt.....You never cease to amaze me.....Go for it.
                      Seth
                      200 mph or bust.......
                        lmao...neat idea!
                        http://cgi.ebay.com/ws/eBayISAPI.dll...m=190343410833
                        • Monster
                          Administrator
                          • 25718
                          Good catch Jim.
                          Not sure if the 1/18 size will be a factor, but it is a 1984 Ford Escort RS 1600i Diecast model car ...
                          • 98ciHemi
                            • Dec 2008
                            • 2425
                            That would sort of work, after removal of the spoiler and the front fascia. The U.S. spec Escorts used a different front end design. The Escort shown there had a stock drag cooefficient of .38. Not sure how good that is, but it gives me an idea where I am at.
                            I cut out my wooden base last night, and now I am putting wooden blocks together to form the bulk of the body. I will take pics of the base when I have it put together.
                            • Monster
                              Administrator
                              • 25718
                              Walt, yeah ... with the model being diecast metal, kinda makes it hard to modify it.
                              I am really interested in the progress and eventual outcome of this project.
                              Keep us updated as you move along.
