    • 11730
    #2491
    Current thinking is fix it well enough to have something to play with and gather parts for the next engine combo...... Not saying exactly what that might be at this point.
      #2492
      I can't remember and you can't search this site for AFR in posts by BBR (ahem, admins... that's pretty crappy). Maybe when you're making a 557 out of it, P51's are in order?
        • 11730
        #2493
        The AFR BBF heads are still vaporware. If I were to do a head change and stay with a BBF, I would go straight to an A460. I think they are less $ than a P51 and have more ultimate potential. Either head would necessitate a dedicated piston or new valve notch.
          #2494
          Mopar....I guess we'll see how they last?
            #2495
            Put an RV cam in it and prep it for your truck
              #2496
              dang, I meant TFS which it also won't let me search for... I figured if you had to go 557, that's a new piston anyway, right? I mean, as long as I'm spending your money and all....
                • 11730
                #2497
                Randal, that thought has crossed my mind more than once. That 545 short block would probably live a long happy life in the truck. I have not made any concrete plans about any of this yet.
                • cstmwgn
                  Wagon Master
                  • 6134
                  #2498
                  I don't have a lot of personal experience with these types of failures but I would have thought that hitting the valve hard enough to break it off and then hitting it a second time to drive it through the seat and up to the larger area of the port to where it could freely travel around surely would cause some trauma to the piston. The intake valve is pretty close to the ring land so there would seem to be a potential for closing that up as well
                  • 85Ram_4Speed
                    • Sep 2014
                    • 29
                    #2499
                    Too bad to see this. My guess is the block is probably fine, but it is still going to be expensive. Pistons and heads or head repair at a minimum.
                      #2500
                      Where I work, we see a lot of engine carnage. Still amazes me and seems physically impossible how a valve head will break off one cylinder and end up in another if the engine is run long enough. Our engine forensic team only gives me "Yep, that will happen." for an explanation.
                        #2501
                        I've seen plenty of strange things and it always amazes me how one thing can make it to different cylinders via the intake tract. When the Bonneville Camaro's Holley vent tube got ingested that thing hit at least three cylinders.
                        I always wonder about the rod bearings or crank when something gets pinched.
                          • 11730
                          #2502
                          I'll post pics of the autopsy when I can do it from a PC. The beat up pistons are still zero deck, so I feel like the rods survived ok, but the rod bearings are probably smeared. While it's not a worst case scenario, it ain't far from it. Lol
                          • mike343sharpstick
                            • 2615
                            #2503
                            Engine failures, while absurdly painfully from a monetary standpoint, are one of the most fascinating parts of this hot rod game. BBR, Love your big-cube ford, hope for all the big bits are ok.
                              • 11730
                              #2504
                              #2 Valve head.
                              #8 piston. The small chunk of valve was in here bouncing around. Note the big dent in the piston at the 6 o'clock position. There is a corresponding dent in the cylinder wall about 3/4" down. It is prob. 0.030" deep, so that cylinder is toast.
                              #8 head. Easily fixable. Might need a new seat. I have not pulled the valves to check.
                              #2 piston. Pretty beat up, but cylinder wall looks ok.
                              #2 head. Pretty beat up as well. Chamber will probably clean up, but the seat and guide will likely need to be replaced.
                              The culprit. Just this tiny amount of interference will eventually kill a valve. This is not where I was expecting to see a valve mark at all. Like I said before, it was not enough interference to notice when rotating the engine over, so I didn't have a clue it was happening. When I built this engine I had a crap ton of P2V clearance, so I didn't bother to check anything. The additional duration, lift and advance all added up to bring that crap ton to a negative value. Totally my mistake for not checking.
                              So. Where do we go from here? That seems to be the question that is burning in everyone's minds at this point. Of course, the cost of each option is a huge factor. Current list of options:
                              1. Pull engine, order 2 pistons and a set of rings and rod bearings, sleeve block (different machine shop this time), fix head and put it back like it was with the old camshaft.
                              2. Pull engine, order 2 pistons and a set of rings and rod bearings, sleeve block (different machine shop this time), fix head and change cam to a hyd ft and never worry about solid roller lifters any more. lol
                              3. Buy a running EFI 460 from a local yard (already located one - $500), use the short block in the Mustang, swap to a bigger hyd ft cam, fix heads, save the EFI stuff to use on the pickup. Essentially killing 2 birds with 1 stone. Car would definitely be slower, but with the smaller, milder engine, I might be more inclined to drive it and enjoy it more.
                              4. Go off the wall, sell off all the BBF stuff and swap in a 5.7L hemi and A518 O/D trans. This actually sounds like the most fun since winter is fast approaching, but is certainly not the lowest cost method and would definitely require selling parts to fund it. (Currently there's a 5.7L on CL here for 900 and an A518 for 650).
                              Been really thinking A LOT about turbochargers lately and the current engine package is not conducive to adding any sort of forced induction. Static compression is just too high and it would need a huge turbo to work properly. Plus 10.00 is as quick as I really need to go and a turbo'd 545 would have the potential to eclipse that by a significant margin. If I wanted to turbo something, an S480 blowing a stock bottom end 460 (10-12 psi) or a stock 5.7L Hemi would probably make enough power to run mid/low-10's up here and still be plenty mild mannered on the street.
                              Anyway, that's where I'm at.
                                #2505
                                owwwww ch.
                                any chance of getting a sonic check and going .080 over on the two holes?
                                /edit - #3 and rummage through the 11-14 liter diesel yards. Stockish 460 and turbo...
