1953 Studebaker / Studillac project...
  • 53 Studillac
    • Nov 2009
    • 157
    #256
    Originally posted by Loren View Post
    Caster doesn't cause bump steer problems, anti-dive geometry changing the caster throughout suspension movement does.
    When the MII spindle it tilted back for more caster the steer arm rotates up and does effect bump steer in that regard. Like you said a new arm will fix that easy enough.
    I took a few more pics while at the shop today. I can't use a longer control arm due to header clearance. I really don't want to build another set of headers just yet. I may have to at some point. I could also raise the engine a little to help also. Tilting the spindle for more caster may actually increase header to UCA clearance.
    A few days on the CAD at night and I should be able to figure out something. Of course it took me years to screw this up!
ID:	1319005 Click image for larger version
ID:	1319006 Click image for larger version
ID:	1319007 Click image for larger version
      • 32276
      #257
      why did you use the spacer ball joints on the upper arms? you already have plenty of camber gain due to the unequal lengths of the upper and lower control arms. Get rid of those ball joints and you'll probably be able to get the castor that you're looking for....
      also, if you're looking to lower the car - lowering spindles are cheap....
      • 53 Studillac
        • Nov 2009
        • 157
        #258
        Ha! I measured those upper ball joints and they look 1/2” long to me as well. I bought these from Heidts years ago. Called tech this week and they acted like they had no idea they were not standard length. The guy also said they are pressed and not so screw-in. I think they are screw-in but hate to mess up a set of stainless arms! At least I could sell these for half off! I have another set somewhere, I will check out those ball joints.
        How much camber gain should I try for?
        The chassis already has 2” drop spindles. I need 3” but can’t find. Worse case I will raise the lower control arm pivot an inch or so. I really want to get body back on chassis to verify but have so many irons in the fire I may have to wait.
          • 32276
          #259
          In the next week or so I'll dig my Fiat out (moving), and take pictures of the upper control arm ball joints... I'm concerned the spindles are too tall too...
          • fatguyzinc
            • Oct 2015
            • 2545
            #260
            yes, pretty sure upper and lower arm should be parallel to each other ideally.
            the upper arm going 'uphill' to spindle looks like hellacious bumpsteer to me.....
            • Loren
              • Jul 2008
              • 5316
              #261
              Just looking at random pics I come across this very old Lotus drawing but it shows what still are considered good control arm angles as seen from the front...the lower about flat, the upper around 5 degrees splayed upward...try to shoot for that, and in a corner you'll get just enough negative camber on the outside wheel and positive on the inside to counter body roll. In the Stude photos it looks like there is about 15 degrees or more on the uppers (I'd have to go get a protractor) which is nutso out-of-whack. Once you've installed normal upper ball joints you still may have to raise the inner shaft mounting via spacers etc., you won't know 'til you get there.
              Part of what makes this drawing clear is it's not showing anti-dive on the upper arm which would have distracted from my point. The Mustang II and any normal car with some weight to it has some anti-dive angle (where the upper arm pivot shaft when seen from the side is at an angle to rearward) so when looking at your a-arms from the front, on the uppers you'll see the front bushing a little higher than the rear, pick the mid-point and consider that the line to see.
Name:	lotus front sus.jpg
              I have little doubt you'll be needing to re-fab the upper arms, doing so will give you a chance to have caster in a good place and the shafts mounted far enough out to clear your headers. I would NOT want to have to re-do the headers just because of that problem more easily solved at the a-arm.
              You got another issue on the Stude, which is the rack looks like it's moved a couple inches forward from the stock MII location, which is going to screw with your ackermann angle, not something you'll notice as speed but you will in a parking lot. Since it's tucked under the pan anyhow, if possible it should be moved back to where the tie rods angle slightly forward as seen from above, not to the rear as they appear now.
              Mustang II's with their tiny 13" wheels had the steering rack and arm height around the mid-point between the upper and lower ball joints as seen from the front and still were able to have the motor which was located over it at a good height from the ground. The Stude of-course has the rack mounted down low for pan clearance to where it's near even with the lower ball joint, in line with where most cars have it, thus the need for the spacers in this case. I see three routes to fix things up in that area...either make custom steering arms to eliminate the spacer scheme and it's twisting moment on the arms, or switch to something like a GM A/G-body spindle that has it's arms in a low position to begin with (I did something like that on my Challenger), or finally set the engine back enough that the rack can go back to it's "stock" Mustang II location, up and rearward with the engine front pulley behind it ala Corvette. That last would probably be a negative packaging-wise for you at this point, I'm just adding the thought.
              • 53 Studillac
                • Nov 2009
                • 157
                #262
                Click image for larger version  Name:	9A13C82D-F399-4DC5-B668-64FCF7ED8DB4.jpg Views:	12 Size:	72.4 KB ID:	1319117Click image for larger version  Name:	2D15428C-964A-46CF-AF14-88DE15DCF504.jpg Views:	12 Size:	93.5 KB ID:	1319118Click image for larger version  Name:	EAA1E72E-BC1C-42AA-BC83-AD078F2409D8.jpg Views:	12 Size:	88.4 KB ID:	1319119​ I managed to get the body sitting on the chassis but needed a hand with the front cap. I only have one more day before I leave for work so this may be as far as I get. I think it’s going to be about where I want it, but need to see the tire in the fender to be sure. There’s about 4” ground clearance at the front xmbr and should be ok for a weekend warrior. Rake measured 2.6 degrees and is a little aggressive by today’s standards. Click image for larger version  Name:	F393B499-6607-4C12-A56A-64DD6BCE9A3E.jpg Views:	13 Size:	101.5 KB ID:	1319116
                • 53 Studillac
                  • Nov 2009
                  • 157
                  #263
ID:	1320956 I've made a lot of progress on the suspension and figured out a few things I did wrong the last time. I just got home from being gone for 4 weeks and I worked on suspension design for 2-3 hours almost every night. I will get into details of that later, but for now wanted to share some pics. It's so hot in MS these days that it's going to be difficult to spend time in the shop for the next couple months. My wife helped me get the front cap and hood set in place for these pics before it was all blown apart again. I have sold the Cadillac engine and am at a crossroads. We are leaning toward something more dependable. My heart is being pulled all over the place, but I have some ideas. Could it really not be a Studillac? More on that later as well. It was now or a ways into the future on getting pics with the engine. These are the first ones I have with the hood and engine fully together! We worked into the night and it's all blown back apart and the engine is ready for transport. It's headed to Kansas.
ID:	1320961 Click image for larger version
ID:	1320957 Click image for larger version
ID:	1320958 Click image for larger version
ID:	1320959 Click image for larger version
                  • 53 Studillac
                    • Nov 2009
                    • 157
                    #264
                    Here's a stance comparison. Doesn't look 2" lower but it is in the front! I'm really liking how she sits now. The updated suspension is about 1/4" narrower on each side to help with fender clearance while turning. If need the fender lip could be dropped just a hair and flared to get the fit to perfectly match the rear but I can't see it being much better!
                    I could slightly raise the rear but am already at 2.6-degree rake. I love the hot rod stance but don't want to go too far.
Name:	compare stance.jpg
                      • 32276
                      #265
                      motor from an escalade is still a Cadillac motor... at least that's the story I'm sticking with in using the 6.0 LS motor in my Buick wagon.
