Remy's '81 Mirada CMX
    #436
    Re: Remy's '81 Mirada CMX
    Bryan
    check that quart container again - if it's really epoxy resin - not polyester resin - it should have almost no odor.
    I worked on our ski boat restoration (partial stringer replacement, complete floor replacement, etc.) inside my shop with the heat going in the winter - there was no issue with epoxy.
    18 minutes is polyester resin - epoxy doesn't have short pot life like that.....
    • Tazracing
      #437
      doesn't matter, if it needs 3 qt.s it'll never stay up anyways, it'll be quite heavy
      • BangShift McT
        The Reason Brian & Chad Drink ... a Lot !
        • 7224
        #438
        All I'm doing is what the factory should have: finished the product. Some of the blame is on me for that one quart: I poured all of it onto the fiberboard right off the bat. I need to mix and pour smaller, workable points and spread it out better.
        Editor-at-Large at...well, here, of course!
        "Remy-Z, you've outdone yourself again, I thought a Mirada was the icing on the cake of rodding, but this Imperial is the spread of little 99-cent candy letters spelling out "EAT ME" on top of that cake."
          #439
          Those bright red velour seats look great. Only problem is that velour is that its real grabby. By the time you slide behind the wheel, your pants end up on backwards.
          • BangShift McT
            • 7224
            #440
            Not real velour...it's the factory cloth material.
              • 32261
              #441
              in thinking more about the roof, I think the best way to repair that will be to tig weld a patch in that is larger then the rusty area - less mess, and easier... so simply get some 18 ga mild steel or even stainless steel to patch the holds (one 3x3, the others 1" round for each hole).
              • BangShift McT
                • 7224
                #442
                So I'm understanding right: A patch for the larger rusthole, smaller patches for the bolt holes. Still wanting a "sleeve" for the passenger B-pillar?
                  • 32261
                  #443
                  Yep, Yep, not a sleeve - same dimensions, we'll cut the metal off and replace
                  • BangShift McT
                    • 7224
                    #444
                    Gotcha. Will stop by the metal shop tomorrow and see what I can get.
                    • BangShift McT
                      • 7224
                      #445
                      Alright, got six 1"x 1" squares for the boltholes, one 4"x 4" for the rust patch, and a piece 12"x 30" for the B-pillar. That last piece is flat, they won't do shaping at all. It's 20ga galvanized sheetmetal. This work ok?
                        • 32261
                        #446
                        that will work fine.... we need to find a way of bending that metal....
                        oh btw - congrats on buying PHR's "10 Classics of tomorrow".... a white version of your car is on the cover
                          #447
                          Galvanized - don't breath deeply while welding that stuff - do plenty of grinding ahead of time.
                          Those fumes are poisonous - weld with plenty of ventilation.
                          • BangShift McT
                            • 7224
                            #448
                            Will keep a safe distance. Oh, BTW..you were right, it was polyester resin. Took 2qt total to finish.
                              #449
                              Polyester - well - it will be hard, and somewhat brittle, but in that application should hopefully work fine - you just need it to hold it's shape right?
                              Good luck with the move man - I don't envy you that task.
                              • BangShift McT
                                • 7224
                                #450
                                All it needed to do was to turn the paper-like layered material into something more useable. The poly resin will work fine in this application.
                                The task actually isn't too bad. The Monte stays up here with the roommate until I can come get it in January, the Mirada is trailered down with me, everything fits in a 20-ft. Penske truck. The hardest part of the move? It's split between getting my bed upstairs by myself in the new place and the cat sedation.
