squirrel's 55 chevy
    #361
    Originally posted by cantvalve16 View Post
    Looks like your "fan shroud" got a second shot at life. What was it in it's first life?lol
    Realty signs from my wife's grandfather. Probably from the 70s.
    • cantvalve16
      • 1558
      #362
      Good stuff. That's hot rodding right there.
      Bakersfield, CA.
        #363
        Don't go too thick on the radiator paint, it'll really cut down on the heat transfer and decrease the air flow.
          #364
          How did you do at the drags?
            #365
            12's......... I don't think he's happy.......
              #366
              12s....yeah, oh well.
              The radiator paint really isn't a big deal. Think about it...most of the heat transfer takes place inside on the fins, where you can't really get much paint. It cools better now, stays 180-190 when the car is moving, although it does heat up when it's sitting still. I haven't been in big city traffic with it yet, though. I need to check the fan clutch, something makes me think it might be getting tired after 15 years. I might also switch to a 2" wide drive belt, which will give more room for the fan. There is very little clearance between the fan and the blower belt and pulleys.
                #367
                To put some context on the drag times, Jim runs it as he brung it other than taking a couple of tool boxes out of the closet he calls a trunk. We had 6200 DA at the beginning of the evening 6000 by the last pass I made at 10:29 PM. 12.07 corrects to 11.33.
                  #368
                  Thanks Bill!
                  Oh...did I mention that I had a fun drive home? I went thru Sonoita, the old boat handles ok on the turns if I slow down to 55. The 3.70 gears are nice on relatively short drives, around 65 mph at 3000 rpm with the 275/60 drag radials.
                    #369
                    Oh yeah....video.
                    • mlcraven
                      • Sep 2008
                      • 1878
                      #370
                      I'll take that over NHRA plastic cars on cable any day!
                      Michael from Hampton Roads
                        #371
                        Discovered a little problem when I was changing ball joints yesterday...lots of wear on my new front tires. I had intended to get it aligned right after I installed the taller springs, but the shop was busy, which put it off for a week or two, then they found the ball joints were worn, which put it off for another couple weeks...meanwhile I was driving around and never even eyeballed the alignment. Mucho toe in, scrubbed off lots of tread. Oh well. They were cheap tires.
                        Got the 33 tooth upper pulley to replace the 35 tooth. It has a 36 tooth lower, so it was 3% over. Now it's 9% over. But boost only went up a little bit, from about 6.5 psi to about 7 psi here in air starved Sierra Vista at 4500 ft elevation.
                        I have a 38 tooth lower pulley on order, but I guess they had to scrounge some beer cans to melt down to make it, so it's taking a long time to get here.
                          #372
                          Great clip, thanks for posting it. Your car really sounds nice!
                            #373
                            Good luck at the HAMB drags... Hope it accomplishes what you desire...
                              #374
                              what does that do to boost when you lose 3500-4000 feet? IIRC, that is a purpose built under 8:1 blower motor, but does that get it close to needing water/meth or race gas?
                              /edit - oh yeah, good luck!
                                #375
                                Thanks!
                                It's been a while since I had the boost gage on it. I seem to recall that driving at lower elevations adds a bit, but I dont remember how much. I guess I'll find out tomorrow.
                                I have put a lot of miles on the car running 87 octane, and I've never heard a ping from the engine. I guess I must be doing something right, 100k miles on the same pistons....
