Re: O2 Sensor Questions
I generally don't think individual bank tuning is worthwhile on a V-engine, because the cylinders will vary more front-to-back then bank-to-bank. I either just put it in one bank or the other, then have someone whose good at plug reading make sure that there's no one or two cylinders significantly leaner than the others.
If you want to be precise, a bung in each individual header tube is the way to go, even if you only check them each one at a time.
