I am including provisions for O2 sensors on the exhaust system that I'm having made, but I have no idea what type of O2 sonsor I would need to fit.
One question is the physical dimension of the sensor, so the bung is fitted in a position that simply provides enough room to fit the sensor.. Are sensors all the same size?
How do I know what electrical connectors will be used?
Another question is what type of sensor would be required for a Lambda readout when dyno testing for example.
Or, is this going to depend on the specific equipment the dyno tester may have as to what sensor will be required?
I wasn't aware of all the varying types available.. http://en.wikipedia.org/wiki/O2_sensor
I really have no idea.. ??? :-[
