got oil out the driver side, have been running the drill for 15 - 20 minutes and the passenger sid eis dry. help???
no oil from passenger side pushrods...
Tags: None
Re: no oil from passenger side pushrods...
Engine type?
Mine were sporatic. Started with three on the drivers side, then two on the passenger side, then I lost track of which ones got oil next, it just took some time. I was probably on it for at least 30 minutes before all the rockers had oil on them.Escaped on a technicality. -
yes engine type. duh. frustrated
350 chevy
the whole driver side is flowing.
letting the drill cool down now while seeking advice.CharlesComment
what are you using to prime with ?if it is just a shaft with out the collar on it like the bottom ot the dist. you may not get oil on the other sideComment
Dave got it, I was using just a shaft with no collar. got another distributor(hard to do on a sunday in a small damn town) ..
ripped it apart, ground down the shaft to fit in the drill, and boom... oil on both sides.
thanks the input guys!CharlesComment
